[fdo][FDO186][New] SDF extended select does not handle base class
Badreddine Karoui
badreddine.karoui at autodesk.com
Fri Sep 22 17:27:35 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO186
Type
Defect
Artifact ID
FDO186 (SDF extended select does not handle base class)
Reported by
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Submission Reviewed set to new value
Yes
- Artifact Status set to new value
New
- Priority set to new value
P2
- Component set to new value
SDF
- Summary set to new value
- Description set to new value
The extended select does not check for the class id when building the indexed scrollable reader. As a result base class record are added to the reader.
- Artifact created
- Subcomponent set to new value
FEATURE COMMANDS
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
