[fdo][FDO188][Modified] FDO: VC fatal error compiling C++ .NET code that access mana...
Greg Boone
greg.boone at autodesk.com
Tue Sep 26 16:58:21 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO188
Type:
Defect
Artifact ID:
FDO188 (FDO: VC fatal error compiling C++ .NET code that access managed FDO API)
Modified by:
Greg Boone
gregboone (greg.boone at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO188: FDO: VC fatal error compiling C++ .NET code that access managed FDO API
Modified
File: trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionary.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionary.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionary.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionary.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionary.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionary.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionary.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionary.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgStringElement.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgStringElement.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgStringElement.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgStringElement.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Common/mgStringElement.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Common/mgStringElement.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Common/mgStringElement.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Common/mgStringElement.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgConnectionManager.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgConnectionManager.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgConnectionManager.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgConnectionManager.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgConnectionManager.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgConnectionManager.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgConnectionManager.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgConnectionManager.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProvider.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProvider.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProvider.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProvider.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProvider.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProvider.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProvider.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProvider.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderNameTokens.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderNameTokens.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderNameTokens.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderNameTokens.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderNameTokens.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderNameTokens.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderNameTokens.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderNameTokens.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderRegistry.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderRegistry.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderRegistry.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderRegistry.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderRegistry.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderRegistry.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderRegistry.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/ClientServices/mgProviderRegistry.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyDictionaryImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyDictionaryImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyDictionaryImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyDictionaryImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyDictionaryImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyDictionaryImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyDictionaryImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyDictionaryImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStoreImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStoreImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStoreImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStoreImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStoreImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStoreImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStoreImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStoreImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStoresImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStoresImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStoresImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStoresImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStoresImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStoresImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStoresImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStoresImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsertImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsertImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsertImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsertImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsertImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsertImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsertImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsertImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwnersImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwnersImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwnersImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwnersImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwnersImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwnersImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwnersImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwnersImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjectsImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjectsImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjectsImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjectsImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjectsImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjectsImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjectsImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjectsImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLTCheckpointImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLTCheckpointImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLTCheckpointImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLTCheckpointImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLTCheckpointImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLTCheckpointImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLTCheckpointImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLTCheckpointImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLongTransactionImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLongTransactionImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLongTransactionImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLongTransactionImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLongTransactionImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLongTransactionImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLongTransactionImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLongTransactionImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLTPrivilegesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLTPrivilegesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLTPrivilegesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLTPrivilegesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLTPrivilegesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLTPrivilegesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLTPrivilegesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLTPrivilegesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTransactionSetImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTransactionSetImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTransactionSetImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTransactionSetImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTransactionSetImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTransactionSetImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTransactionSetImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTransactionSetImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLTCheckpointImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLTCheckpointImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLTCheckpointImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLTCheckpointImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLTCheckpointImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLTCheckpointImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLTCheckpointImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLTCheckpointImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTransactionImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTransactionImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTransactionImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTransactionImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTransactionImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTransactionImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTransactionImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTransactionImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLongTransactionImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLongTransactionImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLongTransactionImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLongTransactionImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLongTransactionImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLongTransactionImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLongTransactionImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLongTransactionImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTransactionImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTransactionImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTransactionImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTransactionImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTransactionImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTransactionImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTransactionImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTransactionImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionCheckpointsImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionCheckpointsImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionCheckpointsImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionCheckpointsImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionCheckpointsImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionCheckpointsImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionCheckpointsImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionCheckpointsImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionPrivilegesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionPrivilegesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionPrivilegesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionPrivilegesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionPrivilegesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionPrivilegesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionPrivilegesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionPrivilegesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsInSetImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsInSetImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsInSetImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsInSetImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsInSetImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsInSetImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsInSetImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTransactionsInSetImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTCheckpointReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTCheckpointReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTCheckpointReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTCheckpointReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTCheckpointReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTCheckpointReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTCheckpointReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTCheckpointReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDirectiveEnumeratorImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDirectiveEnumeratorImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDirectiveEnumeratorImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDirectiveEnumeratorImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDirectiveEnumeratorImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDirectiveEnumeratorImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDirectiveEnumeratorImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDirectiveEnumeratorImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTPrivilegeReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTPrivilegeReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTPrivilegeReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTPrivilegeReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTPrivilegeReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTPrivilegeReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTPrivilegeReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTPrivilegeReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionSetReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionSetReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionSetReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionSetReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionSetReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionSetReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionSetReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransactionSetReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLTCheckpointImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLTCheckpointImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLTCheckpointImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLTCheckpointImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLTCheckpointImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLTCheckpointImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLTCheckpointImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLTCheckpointImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommandImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommandImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommandImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommandImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommandImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommandImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommandImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommandImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchemaImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchemaImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchemaImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchemaImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchemaImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchemaImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchemaImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchemaImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMappingImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMappingImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMappingImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMappingImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMappingImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMappingImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMappingImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMappingImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchemaImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchemaImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchemaImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchemaImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchemaImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchemaImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchemaImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchemaImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpatialContextImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpatialContextImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpatialContextImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpatialContextImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpatialContextImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpatialContextImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpatialContextImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpatialContextImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatialContextImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatialContextImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatialContextImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatialContextImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatialContextImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatialContextImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatialContextImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatialContextImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialContextsImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialContextsImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialContextsImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialContextsImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialContextsImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialContextsImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialContextsImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialContextsImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureUnitImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureUnitImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureUnitImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureUnitImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureUnitImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureUnitImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureUnitImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureUnitImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasureUnitImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasureUnitImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasureUnitImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasureUnitImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasureUnitImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasureUnitImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasureUnitImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasureUnitImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnitsImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnitsImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnitsImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnitsImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnitsImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnitsImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnitsImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnitsImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitReaderImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitReaderImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitReaderImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitReaderImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitReaderImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitReaderImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitReaderImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitReaderImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommandImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommandImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommandImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommandImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommandImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommandImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommandImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommandImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValue.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValue.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValue.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValue.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValue.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValue.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValue.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValue.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValue.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValue.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValue.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValue.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValue.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValue.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValue.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinition.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinition.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinition.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinition.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinition.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinition.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabilitiesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabilitiesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabilitiesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabilitiesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabilitiesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabilitiesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabilitiesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabilitiesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapabilitiesImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapabilitiesImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapabilitiesImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapabilitiesImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapabilitiesImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapabilitiesImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapabilitiesImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapabilitiesImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfoImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfoImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfoImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfoImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfoImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfoImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfoImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfoImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransactionImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransactionImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransactionImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransactionImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransactionImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransactionImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransactionImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransactionImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpression.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpression.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpression.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpression.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpression.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpression.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpression.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpression.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessorImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessorImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessorImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessorImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessorImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessorImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessorImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessorImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgFilter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgFilter.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgFilter.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgFilter.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgFilter.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgFilter.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgFilter.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgFilter.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessorImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessorImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessorImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessorImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessorImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessorImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessorImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessorImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgValueExpressionCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgValueExpressionCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgValueExpressionCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgValueExpressionCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgValueExpressionCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgValueExpressionCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgValueExpressionCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgValueExpressionCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionaryImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionaryImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionaryImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionaryImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionaryImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionaryImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionaryImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionaryImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCapabilities.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCapabilities.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCapabilities.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCapabilities.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCapabilities.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCapabilities.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCapabilities.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCapabilities.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinitionCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinitionCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinitionCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinitionCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinitionCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinitionCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinitionCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinitionCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureClassCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureClassCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureClassCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureClassCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureClassCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureClassCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureClassCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureClassCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureSchemaCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureSchemaCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureSchemaCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureSchemaCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureSchemaCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureSchemaCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureSchemaCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgFeatureSchemaCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinitionCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinitionCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinitionCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinitionCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinitionCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinitionCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinitionCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinitionCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraint.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraint.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraint.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraint.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraint.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraint.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraint.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraint.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyDataPropertyDefinitionCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyDataPropertyDefinitionCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyDataPropertyDefinitionCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyDataPropertyDefinitionCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyDataPropertyDefinitionCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyDataPropertyDefinitionCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyDataPropertyDefinitionCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyDataPropertyDefinitionCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyPropertyDefinitionCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyPropertyDefinitionCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyPropertyDefinitionCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyPropertyDefinitionCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyPropertyDefinitionCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyPropertyDefinitionCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyPropertyDefinitionCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgReadOnlyPropertyDefinitionCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaAttributeDictionary.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaAttributeDictionary.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaAttributeDictionary.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaAttributeDictionary.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaAttributeDictionary.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaAttributeDictionary.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaAttributeDictionary.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaAttributeDictionary.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElement.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElement.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElement.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElement.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElement.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElement.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElement.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElement.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraint.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraint.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraint.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraint.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraint.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraint.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraint.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraint.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraintCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraintCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraintCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraintCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraintCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraintCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraintCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgUniqueConstraintCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureReader.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureReader.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureReader.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureReader.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureReader.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureReader.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureReader.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/mgIDisposableCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/mgIDisposableCollection.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIDisposableCollection.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIDisposableCollection.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/mgIDisposableCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/mgIDisposableCollection.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIDisposableCollection.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIDisposableCollection.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistryImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistryImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistryImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistryImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistryImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistryImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistryImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistryImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstractImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstractImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstractImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstractImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstractImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstractImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstractImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstractImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Runtime/Disposable.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Runtime/Disposable.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Runtime/Disposable.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Runtime/Disposable.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Runtime/Disposable.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Runtime/Disposable.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Runtime/Disposable.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Runtime/Disposable.h&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.cpp?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.cpp&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.cpp&r2=395
File: trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.h?view=diff&rev=395&p1=trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.h&r1=394&p2=trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.h&r2=395
File: trunk/Fdo/Managed/UnitTest/EntryPoint.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/EntryPoint.cs?view=diff&rev=395&p1=trunk/Fdo/Managed/UnitTest/EntryPoint.cs&r1=394&p2=trunk/Fdo/Managed/UnitTest/EntryPoint.cs&r2=395
File: trunk/Fdo/Managed/UnitTest/mgCommonTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgCommonTest.cs?view=diff&rev=395&p1=trunk/Fdo/Managed/UnitTest/mgCommonTest.cs&r1=394&p2=trunk/Fdo/Managed/UnitTest/mgCommonTest.cs&r2=395
File: trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs?view=diff&rev=395&p1=trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs&r1=394&p2=trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs&r2=395
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
