[fdo][FDO189][New] Fixed 762054.01, 775747 Unable to get GML geometry
Romica Dascalescu
romica.dascalescu at autodesk.com
Tue Sep 26 20:36:12 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO189
Type
Defect
Artifact ID
FDO189 (Fixed 762054.01, 775747 Unable to get GML geometry)
Reported by
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Defect Severity set to new value
Medium
- Artifact Status set to new value
New
- Artifact created
- Summary set to new value
- Submission Reviewed set to new value
Yes
- Description set to new value
Replaced the geometries gml geometries names (e.g. "gml/lineStringProperty") with a property named GEOMETRY.
Updated select command to use the right property name when selects.
Used non sensitive case when FeatureCollection element name is searched.
Fixed some issues on build request for WFS server.
Added a new attribute to be able to make the difference between choice and
geometries elements.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
