[fdo][FDO189][Modified] Fixed 762054.01, 775747 Unable to get GML geometry
Romica Dascalescu
romica.dascalescu at autodesk.com
Wed Sep 27 09:06:33 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO189
Type:
Defect
Artifact ID:
FDO189 (Fixed 762054.01, 775747 Unable to get GML geometry)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO189
Modified
File: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h&r1=399&p2=trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/ClassDefinition.cpp&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/FeatureSchema.cpp&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.cpp&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.h?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.h&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/XmlContext.h&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpSchema.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpSchema.cpp?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpSchema.cpp&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpSchema.cpp&r2=400
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpSchema.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpSchema.h?view=diff&rev=400&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpSchema.h&r1=399&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpSchema.h&r2=400
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
