[fdo][FDO192][New] SHP: crash in the presence of NULL geometries
Dan Stoica
dan.stoica at autodesk.com
Thu Sep 28 15:38:35 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO192
Type
Defect
Artifact ID
FDO192 (SHP: crash in the presence of NULL geometries)
Reported by
Dan Stoica
danstoica (dan.stoica at autodesk.com)
New artifact details:
- Description set to new value
A memory violation (NULL pointer) may occur when the SHP contains NULL geometries.
- Artifact created
- Summary set to new value
- Steps to Reproduce set to new value
Use a SHP file containing NULL geometries for opening the connection.
Run a Select command.
Get the geometry properties.
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
