[fdo][FDO194][New] RDBMS providers: Unnecessary constraint queries for List Dat...
Dan Stoica
dan.stoica at autodesk.com
Fri Sep 29 16:39:37 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO194
Type
Defect
Artifact ID
FDO194 (RDBMS providers: Unnecessary constraint queries for List Datastores command.)
Reported by
Dan Stoica
danstoica (dan.stoica at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Steps to Reproduce set to new value
Set FDO_TRACE_FILE=...
For the List Datastores command, the trace file shows a number of unique and check constraint queries being executed. However, this command does not need constraint info.
Similarly, for the FdoISelect command, the trace file shows a number of constraint queries, including some for retrieving constraints for OWM-enabled tables.
Constraint retrieval is expensive and is only needed by the DescribeSchema command. Performance gains can be realized by avoiding these queries when executing other commands.
- Artifact created
- Description set to new value
List Datastores comand is extremely slow.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
