[Fdo_issues] SDF: Regenerate inconsistent key tables.
Brent Robinson
brent.robinson at autodesk.com
Tue Jan 9 16:35:50 EST 2007
This submission adds a check, when the key table for a class is opened,
to see if it is consistent with the class identity properties. SDF key
tables are constructed differently depending on whether the identity is
a single int32 property. If the Key table is not consistent, and the SDF
connection is not readonly, then it is dropped and rebuilt. This solves
a problem where an error occurs when a class, with inconsistent key
table, is deleted.
Revision: 183
Author: brentrobinson
Date: 5:11:44 PM, Tuesday, January 09, 2007
Message:
Regenerate key table when format inconsistent with that of class
identity.
Modified : /branches/3.2.x/Providers/SDF/Src/Provider/KeyDb.cpp
Revision: 618
Date: 5:10:45 PM, Tuesday, January 09, 2007
Message:
Detect unexpected key table format.
Modified : /branches/3.2.x/Utilities/SQLiteInterface/SQLiteTable.cpp
Modified : /branches/3.2.x/Utilities/SQLiteInterface/SQLiteTable.h
Revision: 184
Date: 5:23:46 PM, Tuesday, January 09, 2007
Message:
Merged from 3.2.x branch.
Modified : /trunk/Providers/SDF/Src/Provider/KeyDb.cpp
Revision: 620
Date: 5:23:00 PM, Tuesday, January 09, 2007
Message:
Modified : /trunk/Utilities/SQLiteInterface/SQLiteTable.cpp
Modified : /trunk/Utilities/SQLiteInterface/SQLiteTable.h
URL: http://lists.osgeo.org/pipermail/fdo_issues/attachments/20070109/69c6bc23/attachment.html
More information about the Fdo_issues
