[Fdo_issues] Fixed WFS Null values returned for some properties
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Wed Jan 10 13:27:05 EST 2007
WFS provider:
Fixed inheritance from a class named AbstractFeature (now properties
featureCode and version are provided).
Fixed sometimes the geometry property can be added as object property
(and not as geometry property) if maxOccurs is not 1 (e.g.: unbound).
Fixed a property (object to a class without properties) is marked as
geometry property if the class doesn't have property members.
Removed direct gml objects/associations properties from a class.
E.g. gml:boundedBy from:
<complexType name="TractsType">
<complexContent>
<sequence>
<element minOccurs="0" ref="gml:name" />
<element ref="gml:boundedBy" />
</sequence>
</complexContent>
</complexType>
Removed all unused properties from xlink schema.
Removed all schemas with no classes.
Better detection of geometry type when parsing the data.
branches/3.2.x changes:
r621 | romicadascalescu | 2007-01-10 14:15:01 -0500 (Wed, 10 Jan 2007) |
1 line
******Fdocore******
Modified : Fdo/Unmanaged\Src\Fdo\Xml\GeometryHandler.h
Modified : Fdo/Unmanaged\Src\Fdo\Xml\FeaturePropertyReaderImpl.cpp
Modified : Fdo/Unmanaged\Src\Fdo\Xml\GeometryHandler.cpp
Modified : Fdo/Unmanaged\Src\Fdo\Xml\FeaturePropertyReaderImpl.h
Modified : Fdo/Unmanaged\Src\Fdo\Schema\SchemaFromExternal.xslt
Modified : Fdo/Unmanaged\Src\Fdo\Schema\SchemaFromExternal.h
r86 | romicadascalescu | 2007-01-10 14:15:41 -0500 (Wed, 10 Jan 2007) |
1 line
******WFS******
Modified : Providers/WFS/Src\Provider\FdoWfsConnection.cpp
trunk changes:
r622 | romicadascalescu | 2007-01-10 14:16:15 -0500 (Wed, 10 Jan 2007) |
1 line
******Fdocore******
r87 | romicadascalescu | 2007-01-10 14:16:33 -0500 (Wed, 10 Jan 2007) |
1 line
******WFS******
URL: http://lists.osgeo.org/pipermail/fdo_issues/attachments/20070110/aa1da346/attachment.html
More information about the Fdo_issues
