Connecting to MS SQL 2005
Anant Misra
dowereallyneedanid at yahoo.com
Tue Jun 6 09:56:16 EDT 2006
Hi All,
I am sure a lot of people have already asked this question.
There seems to be a lot of confusion in the open source area. Documentations do not clearly demarkate what is in open source and what is not.
I am evaluating Map Guide to implement some map based systems. I have successfully installed the Map Guide Open source server and I can see a sample PHP application running as well.
What next?
Can I connect to a relational database now?
There seems to be some ODBC connectivity, but I am not sure how to move forward.
1. I need to know how to connect to a sql server database
2. put a sample database into ms sql
3. make a sample application consume data from ms sql.
4. write custom application that can connect to database.
I need to understand if 1,2,3 are possible out of box today. Also, what are the tools, testing frameworks etc to code, debug and run the application.
If for 1, 2, 3 I need to write code, I can write it. But need the basic understanding of what all I need to have in order to jump start with coding on these fronts.
Need help. Thanks.
regards
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
URL: http://lists.osgeo.org/pipermail/fdo_users/attachments/20060606/6bad6350/attachment.html
More information about the Fdo_users
