[mapguide-users] Fdo2Fdo
    Frank Warmerdam
    warmerdam at pobox.com
    Mon Nov  6 14:30:54 EST 2006
Jason Birch wrote:
> It believe that what this means in the short term is that it may be
> necessary to use Autodesk tools to populate it, and that you can not
> just access existing data.  Longer-term, I'm sure that "foreign" schema
> support will be added to this provider, but I think that this still
> requires that you keep the metadata in the same data source (possibly in
> a different schema?).  What I would really like to see is a third level
> of function where all of the mappings are kept internally to FDO without
> affecting the datasource.  I hope that over time FDO will give priority
> to "on-the-fly" access to my data without making the data store
> essentially proprietary to FDO.
Jason,
I'm with you on this one.  I am very frustrated to discover that the FDO
postgis provider won't support access to existing PostGIS datasets.  It
seems antithetical to what I think a "data access" api ought to be doing
for me.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the Fdo_users
