[FOSS-GPS] GPS in space?
Fabrizio Giudici
fabrizio.giudici at tidalwave.it
Wed Nov 5 14:56:10 EST 2008
Risto H. Kurppa wrote:
> Hi!
> Does anyone know how well GPS works in the space? How high is it still
> reliable, what causes the possible errors and so on? If you take a GPS
> device beyond the geostationary level (where the satellites are?),
> what happens? I suppose some customization is required but a normal
> handheld GPS wouldn't handle it properly.
If I'm not wrong the equations have two solutions, one for r < r0 and
another for r > r0 (r0 is the geo-stationary radius). So, you'd need to
give an input to the system about whether you're below or above r0, in
order to choose the proper solution. Also, I've forgotten a lot about
maths since the university, but I'd bet that in such cases, when r
approaches r0 you've a lot of approximation, since the two solutions get
closer.
Fabrizio Giudici, Ph.D. - Java Architect, Project Manager
Tidalwave s.a.s. - "We make Java work. Everywhere."
weblogs.java.net/blog/fabriziogiudici - www.tidalwave.it/blog
Fabrizio.Giudici at tidalwave.it - mobile: +39 348.150.6941
More information about the FOSS-GPS
