[FOSS-GPS] cli gps data logger
Risto H. Kurppa
risto at kurppa.fi
Sat Nov 8 18:32:43 EST 2008
On Sun, Nov 9, 2008 at 12:01 AM, Maciej Piechotka <uzytkownik2 at gmail.com> wrote:
> On Sat, 2008-11-08 at 23:51 +0200, Risto H. Kurppa wrote:
>> Hi!
>> Anyone know a simple command line script/software just to record the
>> gps track/coordinates from a gps device and save it to a text file (in
>> GPX format?) In this case the device is Freerunner where the gps is
>> integrated.
>> thanks!
>> r
> gpspipe + gpsbabel - both should be in the repo.
> Regards
> PS. Which distribution? ASU, 2007.02, ScaredCat, FDOM uses gpsd so you
> can use gpspipe. But FSO use gypsy and I don't know tool.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
I'm running FDOM. Thanks for the tip, I think gpspipe will do it.
r
| risto h. kurppa
| risto at kurppa dot fi
| http://risto.kurppa.fi
More information about the FOSS-GPS
