[FOSS-GPS] High accuracy positioning with low cost GPS devices: a FOSS project
Brent Fraser bfraser at geoanalytic.com
Thu Oct 9 13:16:05 EDT 2008
Eugenio,
  Interesting stuff!  I've experimented with Antonio Tabernero Galan's GAR2RNX to get sub-meter results with a $100 Garmin GPS receiver. See http://lists.burri.to/pipermail/geowanking/2007-August/004314.html for more info.
Other sites of interest for open source precision GPS:
http://facility.unavco.org/software/teqc/teqc.html
http://home.comcast.net/~dmilbert/softs/
http://www.precision-gps.org/
http://www.gpstk.org/bin/view/Documentation/WebHome
And in the spirit of Open source, you might give your Matlab code a try in Octave (http://www.gnu.org/software/octave/index.html)
Best Regards,
Brent Fraser
Eugenio Realini wrote:
> I'm Eugenio Realini, Ph.D. student at Politecnico di Milano, Geomatics
> Laboratory [1] at Como campus (Italy).
> I was simply amazed when I found out this list a few hours ago, since we
> just decided (few days ago) to continue the development of a GPS
> navigation software we have worked on for more than one year as FOSS.
> The software was born as a research/teaching tool to study Kalman
> filtering algorithms on GPS observations and today it has become a
> real-time navigation software that tries to exploit at best low cost GPS
> chipsets in order to obtain highly accurate positioning (20 - 50 cm).
> This is done by applying double differences with respect to a (network
> of) permanent station(s) and linear/surface constraints. It works
> directly on the raw data (code and carrier phase) that can be obtained
> from some GPS chipsets (we are now using u-blox LEA-4T [2]) and relies
> on a GPRS/UMTS Internet connection to get data for the differential
> positioning.
> The software is still highly prototypal and it has been written in the
> framework of two Master's degree theses (a third one has just started).
> Up to now it has been developed in a MATLAB environment, but it is going
> to be converted in ANSI C during the next months.
> We are thinking about designing it to run on Openmoko, but first we have
> to understand if there is any way of obtaining raw data from the u-blox
> GPS chipset it carries inside.
> bye
> Eugenio
> [1] http://geomatica.como.polimi.it/
> [2] http://www.u-blox.com/products/lea_4t.html
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
