[FOSS-GPS] FoxtrotGPS Mapping Library
John Gill
swfiua at gmail.com
Mon Apr 26 09:14:34 EDT 2010
2010/4/25 John Stowers <john.stowers.lists at gmail.com>
> On Wed, Apr 21, 2010 at 3:51 PM, Joshua Judson Rosen <rozzin at geekspace.com
> > wrote:
>> John Stowers <john.stowers.lists at gmail.com> writes:
>> > I was interested to see the announcement of foxtrotgps.
>> > I am the author of the mapping library osm-gps-map
>> > ( http://nzjrs.github.com/osm-gps-map/) which I originally developed
>> > from the tangoGPS codebase when I forked it a few years ago
>> > (for many of the same reasons I suspect you did).
>> > I suspect you could recreate the whole of tangoGPS UI/app in less than a
>> few
>> > thousand lines of C, or a few hundred of python. Additionally v0.5.0 is
>> > available in the lucid repositories.
Re: python version of this.
I wrote johnjohn: https://launchpad.net/johnjohn to run on series60 phones
-- it was inspired by maemo-mapper.
I wrote a little series60 emulation layer so it will run on linux with gtk
-- though that needs a little work.
You are correct though, that it isn't much code to write a good mapping app
in python. Performance is not really an issue -- even on an old nokia 6600
it was ok.
I just got an android, so fear I have to write java now :(
John
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20100426/e8455b77/attachment.html
More information about the FOSS-GPS
