[FOSS-GPS] Request for a release (was: First impressions of
FoxtrotGPS on the Freerunner)
John Stowers
john.stowers.lists at gmail.com
Wed Jun 2 23:26:38 EDT 2010
On Fri, May 28, 2010 at 11:15 AM, John Stowers
<john.stowers.lists at gmail.com> wrote:
>> Also John is improving the osm-gps-map widget in parallel. Right now my branch is still
>> ABI and API compatible with version 0.6 of the widget, but that will change when John
>> releases a stable version with additional track features.
>> I think the first release should still be compatible with the 0.6 version, since it is
>> already in the wild in various distributions, which makes it easier to get some exposure
>> soon. After that, the next release will depend on osm-gps-map HEAD ;)
> I think I have finished most of the improvements you need. It would be
> really helpful if you check out the track-api branch and have a look
> over the changes.
> I will merge this branch to master after some feedback. It is also very
> likely that this will be released as osm-gps-map v1.0.0
This has now been released. The version number is 0.7.0 on account of
I was able to retain API compatibility.
John
More information about the FOSS-GPS
