[FOSS-GPS] FoxtrotGPS 0.99.4 available (also: looking forward...)
Joshua Judson Rosen
rozzin at geekspace.com
Wed Jun 16 00:32:14 EDT 2010
Hello all,
I'm pleased to announce the release of FoxtrotGPS 0.99.4,
now available for download from <http://www.foxtrotgps.org/>.
Please download it, build it, package it, use it, hack on it--
enjoy it!
Marcus, if you're listening: we've made a number of improvements that
I'm sure the users of tangoGPS would appreciate you incorporating--
the most salient ones are listed in the attached NEWS file.
As far as I understand the goals of tangoGPS, the vast majority of
improvements that have been made thus far in FoxtrotGPS should also be
a fit for tangoGPS; even features like zoom-decoupling/detail-scaling,
perhaps--since the GUI has been completely recreated in GladeXML and
any undesired controls, including menu-items, are now trivial to find
and mark as `not visible'.
There are changes coming, however, that may not fit in with the
tangoGPS goals: notably a complete overhaul of the friend-finder
system and, it appears, the replacement of much of the internal
map-loading and -rendering code with calls to osm-gps-map.
Sander van Grieken has done some good work so far porting FoxtrotGPS
to use the osm-gps-map 0.6 API (which I've started reviewing and trying
to fold into my own branch), and John Stowers has been very receptive
to incorporating changes that we need. Sander, I know I owe you another
couple of follow-ups regarding your changes--I appreciate your being
patient as I've sometimes taken some days to write a proper response....
If tangoGPS and FoxtrotGPS are actually to diverge markedly at this
point, then I'm rather inclined to call what follows from this 0.99.4
`beta' release `FoxtrotGPS 1.0', and call the post-divergence series
of releases (with the coming invasive changes) something like
`FoxtrotGPS 1.1'.
Everything should be functionally solid at this point, and the
application should basically be `1.0 quality'. The only obvious
`pre-1.0' issues of which I'm aware in the package as a whole is:
* There's no user manual included.
* Many of the existing translations are only partially done.
I have spent time `shaking bugs out' of both the original code that we
inherited as well as the logic and GladeXML that I and others have added,
and presumably some of the more daring souls out there have been doing
the same with builds that they've made from their own Bazaar branches;
hopefully having an actual release will open things up to a wider audience.
Ideally, I'd like to see some packagers from the distributions pick this up
and run with it--SHR, Debian, Ubuntu, et al.... If you need help, or have
additional requirements that we're not yet meeting--let us know.
To get the OE-based distros started, I've attached a set of bitbake
recipe-files after the NEWS file :)
"Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
This is the first release of FoxtrotGPS since branching from tangoGPS.
The user-visible features and functionality of this release very similar
to those of tangoGPS 0.99.3; FoxtrotGPS does, however, include several fixes
and enhancements:
* Thanks to libgps, FoxtrotGPS supports both the new and old
gpsd protocols transparently.
* The gpsd server address can now be specified either by name or
by IP address.
* The saved gpsd host and port settings are used at startup,
rather than defaulting to `localhost:2947' after each restart.
* Any pending `Load Track...' windows are no longer cancelled by
geocoding.
* A bug causing geotagging of photographs to fail for photographs
taken near lines of latitude or longitude has been fixed.
* Toolbars now have a style more consistent with other GTK+ applications.
* The command option-parser has been replaced:
- The "-fullscreen" option has been replaced by a more standard
"--fullscreen" option.
- A "--display" option is now supported to specify which X11
display to use.
- A standard "--help" option is now supported as a means of
enquiring as to basic information about the program and its
invocation.
* A new `detail-scaling' feature has been added to the main menu,
allowing selection of `fewer/larger details' or `more/smaller details'.
* GUI elements directing the user to `see tangogps.org for more details'
have been removed.
Additionally, packagers and developers should note the following changes:
* All user-visible references in the program to the package-name
(including paths to icons and configuration-data) are defined in
terms of the GNU-standard symbols, "PACKAGE" and "PACKAGE_NAME",
for easy re-branding.
* The internationalisation infrastructure has been updated and
extended using intltool, and now supports translations in
foxtrotgps.desktop.
* Issues triggering warnings from the GNU Autotools and the C
compiler have been have been fixed. It should now be possible to
build using GCC with CFLAGS="-Wall -Werror".
* All libraries on which FoxtrotGPS depends are now specifically
probed by ./configure; the package should no longer fail to build
following successful configuration.
* An `autogen.sh' script hass been added to simplify bootstrapping
the GNU Autotools-based build-infrastructure.
* The output of the ./configure script's probes for depdencies has
been made less confusing by naming each dependency as it is
probed.
* The GUI has been converted to GladeXML, and is dynamically
loaded via libglade. A GladeXML UI definition can be specified
from the command-line via a new "--gui" option.
DESCRIPTION = "FoxtrotGPS is a map and GPS application using OpenStreetMap"
AUTHOR = "Joshua Judson Rosen <rozzin at geekspace.com>"
HOMEPAGE = "http://www.foxtrotgps.org/"
SECTION = "x11/applications"
LICENSE = "GPLv2"
PRIORITY = "optional"
DEPENDS = "curl gtk+ gconf sqlite3 libexif"
SRC_URI = "http://www.foxtrotgps.org/releases/foxtrotgps-${PV}.tar.gz;name=archive"
S = "${WORKDIR}/foxtrotgps-${PV}"
inherit autotools pkgconfig
RRECOMMENDS_${PN} = "gpsd"
RRECOMMENDS_shr = "fso-gpsd"
require foxtrotgps.inc
SRC_URI[archive.md5sum] = "73f03ba1ee1853dea077aa18518222f7"
SRC_URI[archive.sha256sum] = "c7fffa0d45f59de0b858c84e57a6325af78f97f3492ef5e4bd75d5bf0c20d689"
More information about the FOSS-GPS
