[FOSS-GPS] Re: Download-progress callbacks in osm-gps-map
John Stowers john.stowers.lists at gmail.com
Mon May 17 17:12:45 EDT 2010
On Mon, 2010-05-17 at 17:47 +0200, Sander van Grieken wrote:
> On Monday 17 May 2010 01:26:18 John Stowers wrote:
> > > > I suspect I do the former. If this is a problem then I could change to
> > > > ensure that I set the property through the GObject machinery.
> > > Looking it over, "tiles-queued" isn't even settable: but that makes
> > > sense--I don't know what it would even mean to set something like that.
> > > I believe you just need to include a call to g_object_notify() wherever
> > > you're doing something that may change the reported value.
> > > cf. attached patch.
> > Thanks, applied
> For whoever is interested, I have put online my working branch where I'm integrating the
> OsmGpsMap widget here :
> http://www.outrightsolutions.nl/~sander/foxtrotgps/ogm-widget/
> Currently I have migrated GPS updates and the map popup menu, so it is runnable and gives
> an idea of how it'll become. The rest of the functionality is not yet in a working state,
> so expect no POIs, photos, friends etc.
Cool, sounds great!
> Some things I noticed :
> It seems the tiles-queued signal is only triggered when downloading tiles 'on-demand',
> i.e. when dragging the map around. There are no events triggered when doing an explicit
> map download.
OK, this sounds like a bug.
> Also I triggered a 'bug', where I had a huge bbox en a high zoom level (I accidently used
> the old global_zoom variable instead of the internal zoom variable) when starting a map
> download. It ate all my memory. This normally shouldn't happen, because the app will use a
> sane zoom level w.r.t. the bounding box, but maybe some sort of sanity check in OGM is a
> good idea.
Yeah, I have had this before, where it goes and calculates a million
tiles to download if you try and cache the whole world at all zoom
levels.
What do you think a sensible sanity check would be?
> Third issue is that old foxtrotgps also renders a 'bearing' arrow that points to the set
> waypoint, and a distance indicator. AFAICS this is not supported by OGM. Personally I
> don't care much about the waypoint functionality, but others might find it useful. What do
> you think?
I suspect this is something that should be handled by the Overlay/OSD
stuff, although I am not totally opposed to adding it to osm-gps-map, as
it already contains some GPS specific functionality.
> grtz,
> Sander
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
