[FOSS-GPS] FoxtrotGPS doesn't build with libgps older than 2.90
(was: foxtrotGPS compiling issues with Ubuntu 9.10)
Joshua Judson Rosen
rozzin at geekspace.com
Mon May 24 20:20:13 EDT 2010
Timo Juhani Lindfors <timo.lindfors at iki.fi> writes:
> Aapo Rantalainen <aapo.rantalainen at gmail.com> writes:
> > http://www.foxtrotgps.org/build.html
> > 1) on instructions: libglade2.0 might be libglade2-dev
> > 2) libgps-dev is needed but not in list
> Thanks for reporting these! These two are indeed missing from the
> build page. I pinged rozzin on IRC in the hope that he has write
> access to the web page. A bug tracking system would be nice so that
> this does not get forgotten... :-)
Oh, it's not even close to being forgotten--I've applied a fix :)
> > 2B) minimum version of libgps?
> At least libgps 2.94-2 has been tested to work.
I think >= 2.90 should work; at least, it doesn't look like the soname
has changed since before 2.90 was released.
I guess we should actually have a check in ./confgure that checks the
version of libgps and aborts if a sufficiently-high version is not
available....
> > With Ubuntu 9.10 (libgps 2.39-5) I got:
> > gps_functions.c: In function ‘cb_gpsd_data’:
> > gps_functions.c:720: error: ‘struct gps_data_t’ has no member named ‘dop’
There's a sufficient version of libgps-dev in Ubuntu as of 10.04 (Lucid);
in Debian, libgps-dev 2.94 is available in Squeeze (Debian's current
`testing' branch), and appears to install and work fine on Debian 5.0 (Lenny);
I don't know about Ubuntu, but I'd bet that one can install the libgps
packages from Lucid on Karmic--libgps is very light on dependencies.
Is it worthwhile trying to support both the new and old libgps APIs,
do you think?
"Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
More information about the FOSS-GPS
