[FOSS-GPS] RTKLIB: How to use it to develop a cheap
DGPS basestation?
John Morris
john at coyotebush.net
Sat Nov 13 13:50:59 EST 2010
Reading the raw receiver data and generating RTCM messages is pretty
straightforward. If you have suggestions for setting up a Kalman filter
for generating the correction data, that would be very helpful - my linear
algebra is not strong. Better yet, if you know of any code for generating
the corrections, even if in Matlab, I could package it into a GPL package
for a base station.
-----Original Message-----
[mailto:foss-gps-bounces at lists.osgeo.org] On Behalf Of Tomoji Takasu
Sent: Saturday, November 13, 2010 6:44 AM
To: Open Source GPS-related discussion and support
Subject: Re: [FOSS-GPS] RTKLIB: How to use it to develop a cheap DGPS
basestation?
Dear Mauro
> I was trying to follow your code, looking for the step where the
> PseudoRange Correction and the Rate Range Correction (PRC[m] +
> RRC[m/s]) are generated for each satellite (based on the raw data from
> the device used as base and the fixed position of it) before being
> feed to the solution computation for the rover position (when using
> DGPS mode), but I couldn't find it.
Current version (2.4.0) does not include RTCM output for DGPS or RTK base
station. Please use receiver raw proprietary messages for this purpose at
this moment.
I will add RTCM output function in the future version for raw pseudorange
and carrier-phase. I have not decided whether to support RTCM 2 PRC-type
DGPS correction for many existing receivers. If many requests, I will
consider it.
regards,
Tomoji TAKASU
WWW: http://gpspp.sakura.ne.jp
From: "Mauro Ugarte Avilés" <mauro.ugarte at cefop.udec.cl>
Sent: Friday, November 12, 2010 5:17 AM
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] RTKLIB: How to use it to develop a cheap DGPS
basestation?
> Dear Tomoji,
> DGPS base stations are much more expensive than some well known
> receivers that can output raw data, and considering that RTKLIB can
> use that data and correct the pseudoranges of a rover, I was thinking
> if it is possible to use those corrections to output them as RTCM
> SC-104 messages, thus developing a cheap DGPS base station using, for
> example, some decent antenna, an u-blox 5T and RTKLIB with some addition.
> Can you please give me some advice at where to look on RTKLIB code for
> that computation step? Any other suggestion, tip or comment about what
> I'm trying to do will be more than welcome.
> Best regards to you and all list members,
> Mauro Ugarte A.
> PS.: For those of you wondering why do I want to use DGPS in the first
> place, is because here in Chile there is nothing like WAAS, and I need
> to increase accuracy on pedestrian rovers on rural areas, where the
> ammount and quality of the data required for RTK are unachievable with
> small GPS antennas and variable RF links.
> Este correo electrónico y cualquier archivo adjunto son
> confidenciales y son solamente para el uso del individuo o entidad a
> la que van dirigidos.
> Si ha recibido este correo electrónico por error por favor
> notifique al remitente. Este mensaje contiene información
> confidencial dirigida a la persona implicada. Si usted no es esa
> persona no debiera diseminar, distribuir o copiar este mensaje de
> correo electrónico.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription For more information, check
> http://wiki.osgeo.org/wiki/FOSS-GPS
subscription For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
