[FOSS-GPS] Re: RTK-GPS with freerunner: decimeter-level accuracy
with Free Software
Timo Juhani Lindfors
timo.lindfors at iki.fi
Thu Jan 20 05:28:28 EST 2011
RANJAN <infibit at gmail.com> writes:
> To calculated the RTK fix should I collect the base.ubx and rover.ubx
> simultaneously or will it do even if they are collected one after the other
> offline (is data time stamping a concern here)?
The data has timestamps (use ubx-parse.py to look at the data), you'll
only get results for periods where you have data from both base and
rover.
More information about the FOSS-GPS
