[FOSS-GPS] Calculation of satellite position using RINEX file
Tomoji Takasu ttaka at yk.rim.or.jp
Thu May 5 09:04:46 EDT 2011
Dear Abhishek
>                                I want to write a program to calculate the
> satellite position so that I can calculate the differential correction
> from
> the derived pseudo-range.. Can someone guide me thought algorithm and the
> various parameters
You had better to refer the latest formal interface document
for GPS (IS-GPS-200E).
http://www.gps.gov/technical/icwg/
If you want to apply RTCM DGPS corrections, you should also
refer RTCM SC-104 documents. (They are not freely available)
http://www.rtcm.org/
Tomoji TAKASU
WWW: http://gpspp.sakura.ne.jp
From: "Abhishek Jain" <geo.abhishek.iitr at gmail.com>
Sent: Wednesday, May 04, 2011 2:48 PM
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] Calculation of satellite position using RINEX file
> Hi to all,
> from
> various parameters
> I have found following links to calculate the same but all looks a bit
> different ...
> web.cecs.pdx.edu/~ssp/Reports/2006/Monaghan.pdf
> www.ceri.memphis.edu/people/rsmalley/ESCI7355/lab_4.pdf
> trs-new.jpl.nasa.gov/dspace/bitstream/2014/16120/1/00-2027.pdf
> Thanks and Regards,
> Abhishek Jain
> Geomatics Engineering
> IIT Roorkee
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
