[FOSS-GPS] RTKLib MIPS requirements?
Michele Bavaro mic.bavaro at yahoo.co.uk
Tue Aug 14 00:35:01 PDT 2012
Hello Danny,
Have you done any real progress with STM32F4 then?
Best regards,
Michele
On 03/05/2012 14:45, Danny Miller wrote:
> I remember seeing that a long time ago, but forgot about it.  Hmm, it
> does have useful figures.
> The A8 at 600MHz would be capable of 1200 DMIPS.  At 20% utilization
> for 10Hz GPS operation that would indicate 240 DMIPS used, and that's
> with the TMS320C64x DSP.  However, AFAIK that's not a floating-point
> DSP core and I expect you'd have to do a lot of tinkering with the
> compiler to get it to send any math to the DSP core.  I suspect it
> wasn't used.  The article doesn't mention the TMS320C64x DSP except in
> the Beagle specs.
> The STM32F4 is capable of 210 DMIPs.  Hmm, that's troubling. There's
> still overhead which hasn't even come into play yet.  I would expect
> compiling to metal would be substantially more efficient but I don't
> KNOW that.  Then again, it doesn't HAVE to be 10Hz, we could go with
> 5Hz operation, there's no law saying it has to be 10Hz.  Plenty of
> overhead at that speed.
> Danny
> On 5/3/2012 1:04 AM, Michele Bavaro wrote:
>> Dear Danny,
>> Sorry, I assumed that you read this paper
>> http://gpspp.sakura.ne.jp/paper2005/isgps_2009_rtklib_revA.pdf
>> before posting.
>> There you may find more details about RTKLIB computational load at 10Hz.
>> Best regards,
>> Michele
>> On 02/05/2012 23:08, Danny Miller wrote:
>>> Well correct me if I'm wrong but this seems to come down to how many
>>> flops it can do, the moving of variables and such is probably a
>>> minority of the processing. That's why I wanna focus on the flops
>>> requirement.
>>> How much resources does RTKLib consume on Beaglebone?  Because BB
>>> being faster and capable of RTKLib still doesn't establish the
>>> processing requirements.  Is it running at 60% core utilization or 5%?
>>> I did run RTKLib on my i7 Q 740 1.73GHz laptop and the utilization
>>> was basically nil.  I really couldn't determine anything from that,
>>> the usage figure was too low to give a meaningful number, not when
>>> the capabilities are at least 100x greater.  I mean if the usage was
>>> 10% on that i7 I could pretty well dismiss it working on a Cortex
>>> M4.  IIRC it was like a single-digit or fractional % though and the
>>> OS can consume considerable resources managing the busses and
>>> displaying the maps and interfaces so that doesn't mean much.
>>> Raspberry PI would be nice, but I can't get ahold of one, much less
>>> will it be readily available at this time for widespread consumption
>>> if the application worked.  I'm still uncertain if widespread,
>>> long-term, low-price distribution is gonna happen or just turn out
>>> to be vaporware.  STM32F4, anybody CAN order one or a thousand and
>>> get them for $15 or better right now. Still got high hopes of
>>> course.  Raspberry PI also wasn't designed with a lot of low-level
>>> hardware interfacing so it'd still require a daughterboard like the
>>> STM32F4 to interface with a rover's motors and sensors and all.
>>> Danny
>>> On 5/2/2012 3:40 PM, Michele Bavaro wrote:
>>>> Hi Danny,
>>>> I strongly doubt that a STM32F4 will be able to run RTKLIB.
>>>> It's true that it runs on a beaglebone, but Cortex-A8 has around
>>>> 2MIPS/MHz and runs at frequencies close to 1GHz,
>>>> whereas a Cortex-M4 has 1.25MIPS/MHz and runs at frequencies up to
>>>> 150MHz: there is almost one order of magnitude.
>>>> In addition since the structure of rtkrcv is quite strongly coupled
>>>> with a Linux OS,
>>>> there will be a lot of effort required to port it to a lighter
>>>> RTOS, let go to bare metal code.
>>>> But I don't want to discourage you.. if you think it's doable go
>>>> for it :)
>>>> Best regards,
>>>> Michele
>>>> On 02/05/2012 00:15, Danny Miller wrote:
>>>>> STM32F4 "demo board" uses an Arm Cortex m4.  32 bit, 210 DMIPs and
>>>>> a single-precision hardware FPU.  I'm slightly unclear on the
>>>>> memory space it has on this specific board but it should be 192KB
>>>>> SRAM and 1MB flash.  That's my porting plan.
>>>>> If it WORKS, it'll be a great system, these boards are absurdly
>>>>> cheap.  It is several more orders of magnitude of capability than
>>>>> these 8bit PICs and such, but I don't understand the scale of the
>>>>> flops requirement of RTKLib. I know it's somewhere between "much
>>>>> more than any 8-bit controller could ever do" and "won't even make
>>>>> Intel i7 break into a sweat".   And those are wildly different
>>>>> magnitudes.  I don't know exactly where RTKLib 10Hz would be
>>>>> between those.
>>>>> And it's be running RTKLib and just some minor application
>>>>> (navigation and monitoring) code which will not be
>>>>> processor-intensive, and it's not using Linux or an RTOS. So
>>>>> there's not a significant overheat for other tasks and the
>>>>> overhead's timing can be managed predictably and accurately.
>>>>> Pretty much the core can either do it or it can't.
>>>>> Danny
>>>>> On 5/1/2012 4:43 PM, julio menezes wrote:
>>>>>> Hi Danny,
>>>>>>> I have a core with a hardware FPU, but it's only capable of
>>>>>>> doing Single floats, not Double.  It is going to break
>>>>>>> things to implement the specified Double calcs with Single
>>>>>>> precision?  I would assume so, but it's worth asking.
>>>>>> The RTKLIB author T.Takasu and A.Yasuda have  ported RTKLIB to a
>>>>>> BeagleBoard which has an ARM Cortex-A8- with 1 GHz and floating
>>>>>> point, I do not know if double or single precision.
>>>>>> I plan to move in this direction also, may be using a hardware
>>>>>> less powerful but cheaper.
>>>>>> Raspberry Pi
>>>>>> http://www.raspberrypi.org/faqs
>>>>>> The SoC is a Broadcom BCM2835.
>>>>>> This contains an ARM1176JZFS, with floating point, running at
>>>>>> 700Mhz, and a Videocore 4 GPU.
>>>>>> I am waiting, anxiously,  the RTKLIB 2.4.2 version with RTCM-104
>>>>>> phase messages encoder to built a local base station as where I
>>>>>> live there are no near NTRIP network ( less than 10km ).
>>>>>> good luck,
>>>>>> julio menezes
>>>>>> _______________________________________________
>>>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
>>>>>> list.
>>>>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage
>>>>>> your subscription
>>>>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>>>>> list.
>>>>> your subscription
>>>> list.
>>>> your subscription
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> your subscription
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120814/cc56d504/attachment.html>
More information about the FOSS-GPS mailing list
