[FOSS-GPS] New Project with RTKlib & need help.
Timo Juhani Lindfors
timo.lindfors at iki.fi
Mon Jan 2 08:36:40 EST 2012
adioshun <adioshun at gmail.com> writes:
> the goal is to get a better accuracy by merging two GPS information, than
> one.
> [Question 1] Do the RTK and RTKlib are developed for the above reason? My
> goal can be solved by RTKlib?
In RTK you have base and rover receivers. Rover can move freely but base
must stay at a known position.
> [Question 2] To change the raw output format(what RTKlib required), I run an
> u-center and do the follow settings.
> a. view -> Messages view
> b. UBX -> CFG -> PRT
> c. Target = USB / Protocol in = UBX+NMEA+RTCM / Protocol out = raw
> d. press the "send" button
> e. close the box
I have not used u-center (it is non-free) but can you try setting
"Protocol out" to "UBX"?
Then you also want to enable periodic RXM-RAW and RXM-SFRB
reports. These should be in CFG-MSG. Look for "Rate" and set it to
something non-zero. (I am just guessing here since I really have never
even seen u-center).
> Is this right? The RTKlib shows nothing.
Is the GPS receiver sending anything over the serial port? If not, you
can't blame rtklib :-)
More information about the FOSS-GPS
