[FOSS-GPS] A Simple summary for ublox EVK-6T setting
for RTKlib(single Mode)
Mauro Ugarte Avilés
mauro.ugarte at cefop.udec.cl
Wed Jan 4 08:32:28 EST 2012
> p.s My next step is a "moving-base" case with the two EVK-6Ts. Wish me good
> luck~
> Thanks.
Hi Adioshun, is good to know that you solved your first headache!!. We
certainly wish you good luck! (and advice you to get a pack of aspirins
or whatever works with you, because more headaches may come in your way :-))
Use this same mailing list (or another way, RTKlib's website for
instance) to try to contact Tomoji Takasu, the developer of RTKlib, and
ask him if what you are trying to do is possible with RTKlib (moving
base without constraints), just to be sure before you slam your head
against the keyboard!! (and run out of aspirins).
Best regards and good luck,
Mauro Ugarte A.
Este correo electrónico y cualquier archivo adjunto son confidenciales
y son solamente para el uso del individuo o entidad a la que van dirigidos.
Si ha recibido este correo electrónico por error por favor notifique al
remitente. Este mensaje contiene información confidencial dirigida a la
persona implicada. Si usted no es esa persona no debiera diseminar,
distribuir o copiar este mensaje de correo electrónico.
More information about the FOSS-GPS
