[FOSS-GPS] RTKlib begginer's question
Artyom G
gnsssdr at gmail.com
Tue Jul 24 02:06:54 PDT 2012
As I understand if I want to add support of custom receiver then my aim is
to write a function "input_xxx" (like input_oem4 or input_stq etc). These
functions call functions like decode_xxx (like decode_stq or decode_javad
etc) that are responsible for decoding of custom messages.
On Tue, Jul 24, 2012 at 11:55 AM, Artyom G <gnsssdr at gmail.com> wrote:
> Daniel, thanks for suggestion. I know a little Michele and his web-site
> and blog. It was the first place I've started to look closer at RTKlib.
> On Tue, Jul 24, 2012 at 1:10 AM, Daniel Kranich <daniel at nusalaska.com>wrote:
>> Hello!
>> I would suggest taking a look at Michele Bavaro's GPS recievers. I have
>> just bought several and are very pleased with their functionality. I am
>> currently using this board:
>> http://www.onetalent-gnss.com/ideas/usb-hw-receivers/denga10 He
>> suggested that board because of GLONAS support which is helpful in northern
>> latitudes. It is also an NVS board which Michele has ALREADY created a
>> patch for RTKlib which supports the NVS format.
>> Michele has also been invaluable as far as technical support goes, and if
>> you post questions here, I'm sure I can put some of my learned experience
>> to work so that you dont have to bother Michele quite as much.
>> Daniel Kranich
>> Northern Utility ServicesDaniel at NUSalaska.com
>> On 7/23/2012 11:56 AM, Artyom G wrote:
>> Dear collegues,
>> Let me first introduce myself. My name is Artyom Gavrilov. I'm working in
>> the field of GNSS during last 3 years. I'm familiar with software receivers
>> and a little with hardware GPS/GLONASS receivers. There is a web site with
>> some of my project: http://gnss-sdr.ru/index.php?blogid=2 .
>> My current aim is to understand principles of RTK and to study RTKlib.
>> And I have some questions regarding this aim.
>> 1) What is the cheapest way to test RTKlib? As I understand many people
>> use skytraq S1315F, ublox or nsv08c-csm modules. Any other easily
>> affordable alternatives? Which one of the mentioned is the best? (For me
>> the most attractive is nvs08c-csm. Is it good enough?)
>> 2) I've got access to couple of GPS+GLONASS receivers that output raw
>> data (pseudoranges, doppler, phase, etc). But this raw data is output in
>> manufacturer specific format. Is it possible to add support of these
>> receivers to RTKlib? How can I do it myself? Is there any good starting
>> point?
>> Best regards,
>> Artyom
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120724/8ac52671/attachment.html>
More information about the FOSS-GPS
