[FOSS-GPS] Post-processing RINEX to simulate RTK
Mauro Ugarte Avilés mauro.ugarte at cefop.udec.cl
Fri Jun 29 07:04:03 PDT 2012
Dear Antonio,
It's been a while since we talked about RTKLIB and all those networking
options.....how is it going?
I would be glad to know something about your overall results, or some
partial results regarding the monitoring of structures you where
conducting.....I'm planning to learn a little bit of the absolute basics
in the civil engineering fields where precise positioning could apply,
particularly in the area of land surveying, in order to study possible
solutions to some of it's requirements trough the use of rtklib.
(Any other list memeber's comments about some experience in this
particular application of precise positioning (RTK, PPP or even DGPS),
are really welcome.)
Best regards!
Mauro Ugarte A.
Ingeniero de Desarrollo
División de Instrumentación Óptica y Tecnologías de Teledetección
Centro de Óptica y Fotónica
Universidad de Concepción
F/Fax: 2204740 | mauro.ugarte at cefop.udec.cl
On 26/10/11 19:05, António Pestana wrote:
> 2011/10/26 Mauro Ugarte Avilés <mauro.ugarte at cefop.udec.cl
> <mailto:mauro.ugarte at cefop.udec.cl>>
>     Regarding that chapter, you should use as your network topology,
>     the example 4 (Wifi) or 5 (mobile phone network), and replace on
>     both of those examples the block "RTKNAVI" by Spider (and maybe
>     move Spider to the "Base Station" or reference receiver's PC, and
>     "STRSVR" to the remote receiver's PC) . If there is going to be
>     line of sight between both locations, a Wireless Router or Access
>     Point connected at the Base Station's PC Ethernet port (or
>     wirelessly), an a USB wireless adapter with detachable antenna at
>     the rover's PC (this one, for example:
>     http://www.tp-link.com/en/products/details/?model=TL-WN722N), with
>     both antennas (the AP/router and the USB adapter) replaced by a
>     directional Wifi antenna like this one:
>     http://www.tiendecita.com/antena-wifi-planar-estanca-marca-abaks-p-99.html,
>     should do it. (Note that the antenna does not include the coaxial
>     cable needed to connect the antenna to the AP/router (that by the
>     way has to have a detachable antenna also, in order to replace
>     it), but that cable can be easily found on computer stores). The
>     USB wireless adapter used at the remote receiver's PC should be
>     placed inside the box behind the antenna, were the RP-SMA
>     connector is.
> Once again very useful tips. Thanks.
>     My fault, no examples...but at least RTKLIB has a manual....and
>     there are screen captures on it!! At the GNSS positioning
>     techniques FOSS world, those features are not very usual... ;-).
> Yes. I must agree with you. The manual is very good.
>     Based on that brief descriptions, you would be able to find better
>     explanations somewhere else: papers, doctorate theses, GNSS
>     equipment manufacturers, etc.
> That's what I'm trying to do these days...
>     You will be sensing large structures, right? In that case, I would
>     go with "static" (static rover, static reference), not
>     "moving-base" (moving rover, moving reference) nor "fixed"
>     (constant distance between rover and base). Maybe you could go
>     with kinematic too, if the real-time displacements and deflections
>     of the structures studied can be considered as "movement".
> My structures move at relatively high frequencies (say from 0,1 to 5
> Hz). Most of the movements are small (a few centimeters at most).
> Best regards
> Antonio
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
   Este correo electrónico y  cualquier archivo adjunto son confidenciales
y son solamente para el uso del individuo o entidad a la que van dirigidos.
Si ha  recibido  este correo  electrónico por error por favor notifique al
remitente.  Este  mensaje contiene  información confidencial dirigida a la
persona  implicada.  Si  usted  no  es  esa  persona  no debiera diseminar,
distribuir o copiar este mensaje de correo electrónico.
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120629/2a55f799/attachment.html>
More information about the FOSS-GPS mailing list
