[FOSS-GPS] rtklib: convbin in rtklib 2.4.1 does not work
Nick Østergaard
oe.nick at gmail.com
Mon May 7 02:14:12 EDT 2012
Hi
Yep that seems to do the trick. It is not mentioned in the rtklib
manual, under the CONVBIN synopsis, that it is nesesary though.
-Nick
2012/5/6 Michele Bavaro <mic.bavaro at yahoo.co.uk>:
> Hi Nick,
> As you can see, it's a file path problem that leads to a file open error.
> If you specify the output path everything will work as expected, e.g.
> ./convbin /tmp/neo1.ubx -d .
> Bests,
> Michele
> On 06/05/2012 13:09, Nick Østergaard wrote:
>> Dear Tomoji
>> I am pretty new to this great rtklib, but I have found that the
>> application program 'convbin' does not work properly in rtklib 2.4.1.
>> It works fine in rtklib 2.4.0. You should know that I am using it in
>> linux. Following is te output from convbin, where the sample file is
>> from lindi at http://iki.fi/lindi/gps/experiment/1/neo1.ubx.
>> The output if I use 2.4.1:
>> ┌─[nickoe /tmp/rtklib_2.4.1/app/convbin/gcc]
>> └─ $ ./convbin /tmp/neo1.ubx
>> input file : /tmp/neo1.ubx (u-blox)
>> ->rinex obs : /neo1.obs
>> ->rinex nav : /neo1.nav
>> ->rinex gnav: /neo1.gnav
>> ->rinex hnav: /neo1.hnav
>> ->rinex qnav: /neo1.qnav
>> ->sbas log : /neo1.sbs
>> file open error: /neo1.obs
>> └─ $ ls /tmp/
>> roverlog1.rawlog rtklib_2.4.1
>> roverlog1.ubx rtknavi.conf
>> neo1.ubx
>> The output if I use 2.4.0:
>> ┌─[nickoe /tmp/rtklib_2.4.0/app/convbin/gcc]
>> ->rinex obs : /tmp/neo1.obs
>> ->rinex nav : /tmp/neo1.nav
>> ->rinex gnav: /tmp/neo1.gnav
>> ->rinex hnav: /tmp/neo1.hnav
>> ->sbas log : /tmp/neo1.sbs
>> 2010/07/26 08:03:18-07/26 12:58:54: O=17733 N=50 G=0 H=202 S=25055 E=1
>> └─ $ ls /tmp/
>> neo1.ubx rtklib_2.4.0
>> neo1.hnav rtklib_2.4.0.zip
>> neo1.nav rtklib_2.4.1
>> neo1.obs rtknavi.conf
>> neo1.pos
>> neo1.sbs
>> In 2.4.1 it does not output any files.
>> Sincerely
>> Nick Østergaard
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> subscription
More information about the FOSS-GPS
