[FOSS-GPS] rtklib ( no base station observation data for rtk
Mauro Ugarte Avilés
mauro.ugarte at cefop.udec.cl
Tue May 8 12:55:08 EDT 2012
Hi Willem, did you set up the output of RXM-RAW messages on both
receivers and RXM-SFRB message on one of them (preferably on the
receiver connected to the PC running rtknavi, to reduce the data
transfer load managed by tcpsrv-tcpclient)?. You also need to set the
"RAW" protocol mode on the ports used to output those messages in both
receivers.
Best regards,
Mauro Ugarte A.
On 08/05/12 09:47, Willem Dantuma wrote:
> Hello All,
> I'am trying to make a base station + rover setup with 2 Ublox EVK-6T
> receivers and rtklib 2.4.1 all is going as expected thank to the great
> posts on this list. but now i having some trouble and always get a (
> no base station observation data for rtk message ) on the rover and
> never getting a FIX ( only SINGLE).
> This is my setup:
> Base station
> 1 ublox EVK 6T + rtkrcv on linux
> input 1 - serial
> output 1 - tcpsvr
> Rover
> 1 ublox EVK 6T + rtknavi on windows
> input 1 - serial
> input 2 - tcpclient
> Rover is connecting to the server fine and messages are send to the
> rover ( verified using the monitor in rtknavi ).
> Any ideas are welcome...
> Thanks in advance
> Willem
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Este correo electrónico y cualquier archivo adjunto son confidenciales
y son solamente para el uso del individuo o entidad a la que van dirigidos.
Si ha recibido este correo electrónico por error por favor notifique al
remitente. Este mensaje contiene información confidencial dirigida a la
persona implicada. Si usted no es esa persona no debiera diseminar,
distribuir o copiar este mensaje de correo electrónico.
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20120508/5acc91bc/attachment.html
More information about the FOSS-GPS
