[FOSS-GPS] FoxtrotGPS: add track-logging toggle to the toolbar? (was: FoxtrotGPS - are suggestions welcome ?)
David Bannon
dbannon at internode.on.net
Thu Nov 1 02:24:52 PDT 2012
Joshua, that works beautifully !
Makes it heaps easier to record logs. Thanks a lot.
I'd suggest two minor improvements. Firstly, can you add a help text
for the flag that pops up when a user hovers a mouse over the icon ?
I'd suggest "start/stop track logging". Secondly, and perhaps a bit
harder and maybe not so important, the toggled icon does not look
massively different to the untoggled. I guess its dependent on the
widget set you are using but if its easy, making it look more
distinctive would be good.
But, either way, thanks heaps, great response.
David
----- Original Message -----
To: "David Bannon"
Cc: "Open Source GPS-related discussion and support"
Sent: Tue, 30 Oct 2012 00:54:18 -0400
Subject: [FOSS-GPS] FoxtrotGPS: add track-logging toggle to the
"David Bannon" writes:
> > Do you mean the popup/context menu, or the toolbar?
> If you mean where I would like a "logging on / off" icon and if by
the
> 'toolbar' you mean the structure on the left hand side of the
window,
> then its the toolbar.
OK. If my screen is any indication, it looks like there's enough room
on that side toolbar for a couple of extra buttons even when the
window
is ~500 pixels high, and they gracefully `fall off the bottom' when
the window gets smaller down to about 400 pixels (below which there's
not even room to show the existing buttons). Let's try it.
I have a change that I think does what you're asking for:
https://code.launchpad.net/~rozzin/foxtrotgps/tracklog-toggle-toolbutton
It adds a toggle-button to the toolbar, synchronised with the
checkbox
in the info/control panel.
Would you be able to try that out?
> > Also, what about the `split track', and `load track' functions?
> The split track function is useful but not useful enough to justify
having the
> right hand side "Control Panel" (if thats what you call it)
displayed all the
> time. So, I'd be happy to click the toolbar icon twice to achieve
the same
> effect.
> The "load track" and "clear" buttons are really used once you are
reviewing
> collected data and are fine remaining in the control panel tab. I'd
suggest
> that tab remain where it is pretty much unchanged and regard the
toolbar icon
> I am requesting as an alternative way to work.
OK.
> Keyboard shortcuts might also be another useful alternative, ctrl-l
to
> toggle logging, maybe something to zoom in or out....
Yes.
There are actually already few keyboard shortcuts in place:
* "i" or page-up zooms in (as does scroll-up via they pointer)
* "o" or page-down zooms out (as does scroll-down via the pointer)
* Ctrl+t brings up the `Load track' dialog
* Left, Right, Up, and Down pan the map West, East, North, or South
respectively.
* "a" toggles autocenter
* "F11" toggles fullscreen mode
* "m" shows/hides the info/control panel
* 1-8 select different maps
None of those have been properly documented, though..., and it looks
like
there's a bug where the wrong widget has focus by default, so you
have
to hit Tab to move focus from the toolbar to the map-widget before
any
of those keys will work.... I just pushed a couple of changes
to the bzr repository that address both of those issues.
Adding an "l for logging" key seems like it would make sense.
Though, now that I think of it..., I'm sort-of inclined to make it
"t for track-logging" just to keep the H/J/K/L keys free in case
someone asks for vi-style navigation keys....
"Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
> From:
> To:
> "David Bannon"
> Cc:
> Sent:
> Sat, 27 Oct 2012 14:47:36 -0400
> Subject:
> Re: [FOSS-GPS] FoxtrotGPS - are suggestions welcome ?
> > I contribute data to OSM and use FoxtrotGPS mainly for that
> > purpose. At present, to control the stopping and starting of
logging,
> > I need to show the large "control panel" (? for lack of a better
name)
> > onf the right hand side. browse through several pages and then
click a
> > quite small text based tick box. This control panel takes up a
whole
> > lot of screen space and the tick box is quite awkward to find,
> > especially if you are on the move. I would greatly prefer if this
> > functionality was on the left hand menu, fronted with a
reasonable
> > sized icon that could (eg) change colour when active.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
@internode.on.net>@lists.osgeo.org>@internode.on.net>@lists.osgeo.org>@internode.on.net>
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20121101/37baa9d6/attachment.html>
More information about the FOSS-GPS
