[FOSS-GPS] GPS orbits computations
Eugenio Realini
eugenio.realini at gmail.com
Tue Oct 2 18:44:55 PDT 2012
Hi Antonio,
you should use the closest set in time available with respect to epoch
t. You can use the TOE (Time Of Ephemeris) for doing that.
Cheers,
Eugenio
2012/10/1 António Pestana <afsm.pestana at gmail.com>:
> I want to to compute the instantaneous position (GPS84) of a GPS satellite
> at a given epoch t (GPS time) using broadcast navigation data. I'm using
> RINEX 2.10 nav files. Often I have multiple ephemerides available for the
> same satellite. Which one should I use?
> Regards
> Antonio
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
