[FOSS-GPS] GPS orbits computations
Eugenio Realini eugenio.realini at gmail.com
Wed Oct 3 19:10:48 PDT 2012
Hi Antonio,
that's right. The closer epoch t is to TOE, the better that specific
ephemeris set is able to describe the satellite orbit.
As far as I understand, at least :)
Eugenio
2012/10/3 António Pestana <afsm.pestana at gmail.com>
> Hi Eugenio
> Thanks. If I understand you correctly, it doesn't matter if TOE is before
> or after the epoch t. Am I right?
> Regards
> Antonio
> 2012/10/3 Eugenio Realini <eugenio.realini at gmail.com>
>> Hi Antonio,
>> you should use the closest set in time available with respect to epoch
>> t. You can use the TOE (Time Of Ephemeris) for doing that.
>> Cheers,
>> Eugenio
>> 2012/10/1 António Pestana <afsm.pestana at gmail.com>:
>> > I want to to compute the instantaneous position (GPS84) of a GPS
>> satellite
>> > at a given epoch t (GPS time) using broadcast navigation data. I'm using
>> > RINEX 2.10 nav files. Often I have multiple ephemerides available for
>> the
>> > same satellite. Which one should I use?
>> > Regards
>> > Antonio
>> > _______________________________________________
>> > This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> > Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> > subscription
>> > For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> subscription
> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20121004/75d2775d/attachment.html>
More information about the FOSS-GPS mailing list
