[FOSS-GPS] GPS issues for Ethiopia
andrea antonello andrea.antonello at gmail.com
Fri Oct 26 05:11:14 PDT 2012
Dear Iulio,
>> We are planning a educational project for water management
>> networks in
>> Ethiopia
> Good luck for your project, especially because it is educational.
Thank you!
> You said do not have a precise vertical network, even so you can use GPS and mix it with traditional topographic leveling for critical nstallations.
> I do not know your project extension and precision requirements but i believe you can use GPS and a relative geoid undulation to correct the geometric height differences and get an almost orthometric height.
> I have used EGM2008 and  this way and get realy good results.
> Pay attention on EGM2008 if you have no gravitational anomalies in your working area and for sure this simple differential model will give you acceptable results.
> Hj - Hi = (hj - hi) - ( Nj - Ni )
> H=orthometric
> h=geometric
> N=geoid ondulation
> http://www.fig.net/pub/athens/papers/ts07/ts07_8_roman.pdf
Thanks you, since we are talking about small networks, I think we
should really get good results, I appreciate you backup my guess.
I will read throught the documentation, thanks!
Best regards,
Andrea
> best regards,
> julio menezes
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
