[FOSS-GPS] FoxtrotGPS: now with HTML/PDF/texinfo docs (was: building documentation)
David Bannon dbannon at internode.on.net
Thu Jan 10 02:07:17 PST 2013
Joshua, thats good, glad you are on top of it. I note the HTML version
has made it to the web site. Now, thats great but I note it still has my
reference to carefully breed mice in Section 1.1
You seem to be the new owner of this document, maybe it needs that
cleaning up a little ?
David
On Sun, 2013-01-06 at 23:19 -0500, Joshua Judson Rosen wrote:
> David Bannon <dbannon at internode.on.net> writes:
> > On Wed, 2012-12-12 at 19:06 -0500, Joshua Judson Rosen wrote:
> > > I'll put together a couple of bzr branches that can actually build
> > > docs one way or the other, and we can compare them.
> > Joshua, I note this is still pending.
> Mm--I blame the myriad holiday distractions....
> Good news, though--I did finally emerge from the holidays and find some
> time to pull everything together:
> I just pushed up the texinfo changeover, including your additions
> and Til's, into the foxtrotgps-dev branch in bzr; and I also put
> the manual in HTML format up on the website (there's also a PDF
> up there in the same directory as the HTML manual, I just haven't
> found a place to put a link to it...). I took a few minor
> liberties before committing: fixed typos, normalised punctuation
> (e.g.: "eg" -> "e.g.") and screenshot file-names, added more hyperlinks,
> broke the "menu of common operations, allowing such things as..."
> paragraph out into a bulletted list (following advice from a local
> proofreader), used the same `main window' screenshot as is already
> on the website....
> For the time being, I've collected all of the screenshots into
> a branch on Launchpad, and added a Makefile rule that fetches them
> on demand. If you invoke any of the `make dist' targets, all of
> the screenshots will get bundled into the resulting tarball/directory
> along with the full manual in HTML format and the `shim' man page,
> and those are installed by `make install'.
> The PDF version of the manual builds with "make -C doc pdf"
> (and PostScript and DVI outputs can be generated similarly),
> but it doesn't happen by default (I think you were right
> that HTML is probably a better default format than PDF).
> "make -C doc foxtrotgps.txt" also works, but also doesn't
> happen by default (should it?).
> I've run through a few tests to verify, and I believe that building
> from tarballs output by `make dist' will not require help2man,
> makeinfo, or any of the other Texinfo utilties out of the box.
> The tarballs are *much* larger that they have been up to now,
> though (~2 MB compressed with gzip, ~1.7 MB compressed with xz,
> which is ~4x the size of the 1.1.1 release tarballs!).
> Oh--I also turned Automake's `maintainer-mode' on *by default*.
> Tracking the version.texi in bzr actually turned out to be
> a little problematic, because it ends up getting updated
> every time someone runs ./autogen.sh or otherwise needs
> to generate the "configure" script from configure.in; just
> turning maintainer-mode on by default solves that problem
> handily, but also seems like a good idea in general (see
> the comments on commit #224).
More information about the FOSS-GPS mailing list
