[FOSS-GPS] Differential GPS with RTKLIB 2.4.2
Gordon Williams
gwilliams at ncf.ca
Thu Jun 6 13:01:58 PDT 2013
Likely a setup problem or some bug, but could one antenna be affecting the other antenna at such a close distance? What happens if you move them 2m apart?
This is something that I want to try once I get my second ublox datalogger working, so I hope that you will provide some feedback on what worked for you.
Gordon Williams
----- Original Message -----
To: foss-gps at lists.osgeo.org
Sent: Wednesday, June 05, 2013 11:23 PM
Subject: [FOSS-GPS] Differential GPS with RTKLIB 2.4.2
Hello,
I’am trying to build a differential GPS using RTKLIB 2.4.2.
The accuracy that I can achieve is around +/-2 m.
Which is about the same that one of my sensor achieves in PPP kinematic mode.
My expectation is to achieve something around +/- 5 cm.
The set up:
Sensors 2 UBLOX NEO6P
Antenna Trimble Bullet III
The sensors are installed on the roof with a free 360 °view. RTKLIB indicates that 6 to 8 Satellites are visible. The distance between both sensors is < 20 cm.
Ublox Center Configuration:
NEMA Child Messages Disabled
UBX Child Messages Enabled
RXM-RAW Enabled
RXM SFRB Enabled
RXM-RATE 200ms
Dynamik Mode Pedestrian
RTKLIB Configuration
Input Streams
Rover Serial COM 1, UBLOX
Base Serial COM 2, UBLOX
Log Streams
Rover to File
Base to File
Solution Log
Solution 1 toFile
Solution 2 to File
Options
Positions
Base Station Position is acquired by 10hour static measurement.
So, with this setting I usually get FLOAT (90%) and intermediate FIX (10%) soloutions with an accuracy of +/- 2m.
Is my expectation wrong?
Have I selected the correct configuration?
When I run the sensors stand alone in PPP Kinematic mode I also get around +/- 2m accuracy which matches the manufacturer provided data. So I assume that my Antenna, Sensor are working fine.
Can somebody HELP ?
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20130606/e52132ab/attachment.html>
More information about the FOSS-GPS
