[FOSS-GPS] UCenter enable RXM-RAW packets
Brent Fraser
bfraser at geoanalytic.com
Fri Mar 1 07:23:57 PST 2013
Jack,
I just received a u-Blox Neo6P-PPP (logs raw measurements), enabled RAW
and SBX in u-center, then saved the config (see attached).
I too would like to see if a LEA-6H can log raw measurements given
instructions via a Ardupilot-Mega. Of course the other question is "log
where?" on my APM 2.5. I'll likely need to attach a serial logger board.
And there is some discussion on DiyDrones:
http://diydrones.com/profiles/blogs/u-blox-neo-6p-gps-chip?xg_source=activity
Best Regards,
Brent Fraser
On 3/1/2013 12:42 AM, Jack Acer wrote:
> I am currently using the ardupilot Ublox config file. Does editting this
> change the firmware?
> https://code.google.com/p/ardupilot-mega/source/browse/libraries/AP_GPS/config/3DR-Ublox.txt
> I was thinking it involved changing something in:
> CFG-RXM - 06 11 02 00 08 00
> however I am not sure what to do.
> Thanks,
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/UCenter-enable-RXM-RAW-packets-tp7572639p7572643.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
MON-VER - 0A 04 28 00 36 2E 30 32 20 28 33 36 30 32 33 29 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 34 30 30 30 37 00 00
CFG-ANT - 06 13 04 00 1B 00 8B A9
CFG-DAT - 06 06 02 00 00 00
CFG-FXN - 06 0E 24 00 0C 00 00 00 00 00 00 00 00 00 00 00 10 27 00 00 10 27 00 00 D0 07 00 00 18 FC FF FF 00 00 00 00 00 00 00 00
CFG-INF - 06 02 0A 00 00 00 00 00 FF FF FF FF 00 00
CFG-INF - 06 02 0A 00 01 00 00 00 87 87 87 87 87 87
CFG-INF - 06 02 0A 00 03 00 00 00 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 01 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 02 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 03 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 04 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 06 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 11 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 12 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 20 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 21 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 22 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 30 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 01 32 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 02 10 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 02 11 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 02 20 00 00 00 1E 00 00
CFG-MSG - 06 01 08 00 02 23 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 02 30 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 02 31 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0A 02 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0A 05 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0A 06 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0A 07 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0A 08 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0A 09 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0A 0A 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0A 20 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0A 21 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0B 00 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0B 30 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0B 31 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0B 32 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0D 01 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 0D 03 00 00 00 01 00 00
CFG-MSG - 06 01 08 00 F0 00 01 01 01 00 01 01
CFG-MSG - 06 01 08 00 F0 01 01 01 01 00 01 01
CFG-MSG - 06 01 08 00 F0 02 01 01 01 00 01 01
CFG-MSG - 06 01 08 00 F0 03 01 01 01 00 01 01
CFG-MSG - 06 01 08 00 F0 04 01 01 01 00 01 01
CFG-MSG - 06 01 08 00 F0 05 01 01 01 00 01 01
CFG-MSG - 06 01 08 00 F0 06 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 07 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 08 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 09 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 0A 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F1 00 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F1 03 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F1 04 00 00 00 00 00 00
CFG-NAV5 - 06 24 24 00 FF FF 02 03 00 00 00 00 10 27 00 00 05 00 FA 00 FA 00 64 00 2C 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CFG-NAVX5 - 06 23 28 00 00 00 FF 3F FF FF FF FF 03 02 03 10 0A 00 00 01 00 00 F8 05 00 00 00 00 01 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
CFG-NMEA - 06 17 04 00 00 23 00 02
CFG-PM - 06 32 18 00 00 06 00 00 04 90 00 00 E8 03 00 00 10 27 00 00 00 00 00 00 02 00 00 00
CFG-PRT - 06 00 14 00 00 12 42 00 84 00 00 00 00 00 00 00 03 00 03 00 00 00 00 00
CFG-PRT - 06 00 14 00 01 13 42 00 C0 08 00 00 80 25 00 00 03 00 03 00 00 00 00 00
CFG-PRT - 06 00 14 00 02 13 42 00 C0 08 00 00 80 25 00 00 00 00 00 00 00 00 00 00
CFG-PRT - 06 00 14 00 03 1B 42 00 00 00 00 00 00 00 00 00 03 00 03 00 00 00 00 00
CFG-PRT - 06 00 14 00 04 13 42 00 00 32 00 00 00 00 00 00 03 00 03 00 00 00 00 00
CFG-RATE - 06 08 06 00 E8 03 01 00 01 00
CFG-RINV - 06 34 18 00 00 4E 6F 74 69 63 65 3A 20 6E 6F 20 64 61 74 61 20 73 61 76 65 64 21 00
CFG-RXM - 06 11 02 00 00 00
CFG-SBAS - 06 16 08 00 01 03 03 00 D5 CA 06 00
CFG-TP - 06 07 14 00 40 42 0F 00 A0 86 01 00 01 01 00 00 32 00 00 00 00 00 00 00
CFG-TP5 - 06 31 20 00 00 13 42 00 32 00 00 00 40 42 0F 00 40 42 0F 00 00 00 00 00 A0 86 01 00 00 00 00 00 F7 00 00 00
CFG-TP5 - 06 31 20 00 01 13 42 00 32 00 00 00 04 00 00 00 01 00 00 00 48 E8 01 00 A0 86 01 00 00 00 00 00 FE 00 00 00
CFG-USB - 06 1B 6C 00 46 15 A6 01 00 00 00 00 64 00 00 00 75 2D 62 6C 6F 78 20 41 47 20 2D 20 77 77 77 2E 75 2D 62 6C 6F 78 2E 63 6F 6D 00 00 00 00 00 00 75 2D 62 6C 6F 78 20 36 20 20 2D 20 20 47 50 53 20 52 65 63 65 69 76 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
More information about the FOSS-GPS
