[FOSS-GPS] FoxtrotGPS chops off details on refresh
Svenn Are Bjerkem
svenn.bjerkem at googlemail.com
Fri Oct 25 12:59:08 PDT 2013
running foxtrotgps 1.1.1 on raspberry pi with gpsfake -c 0.1 on an NMEA
file from a GPS which had a 1 Hz update frequency. The replay is a bit
faster than real-time, but I notice that track data is lost on the screen
track when it is updated. I mean by this that abrupt direction changes and
turns are just cut away and replaced with a single point. Is there any
filtering happening in foxtrotgps which can be modified in source or by
configuration?
Svenn
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20131025/406371ad/attachment.html>
More information about the FOSS-GPS
