[FOSS-GPS] RTKLIB raw data
Tomoji TAKASU ttaka at yk.rim.or.jp
Sat Oct 26 09:07:15 PDT 2013
Dear hnightd
> I'm new in these wanderings with gps rtklib. I've been searching for some
> information on the intended and found nothing.
> What I was wondering if anyone knew, it was the function that takes the
> raw
> data directly from the GPS. I've looked at the file in the file rtkrcv.c
> and
> rtkraw.c and not found anything.
> If someone can explain me or tell how it works was grateful.
RTKLIB has a little complicated structure but
the basic APIs are not so difficult to use.
To decode input receiver raw data stream,
use input_rtcm2() or input_rtcm3() for RTCM
and input_raw() for other proprietary formats.
These APIs feed a byte stream and return
except for 0 if a raw message received. The
received message is saved in observation or
navigation data buffer in rtcm_t or raw_t
struct.
After receiving the observation data, you can
call rtkpos() to process them.
For details of real-time cycle, read codes of
rtksvrthread() in rtksvr.c.
I am going to prepare an API reference manual
for programers as well as python-binding of
APIs. They will be involved in future versions.
regards,
Tomoji TAKASU
Sent: Saturday, October 26, 2013 4:08 AM
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] RTKLIB raw data
> Hey,
> raw
> and
> Yours sincerely
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-raw-data-tp7572740.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> ‚±‚̃ƒbƒZ[ƒW‚ɃEƒCƒ‹ƒX‚ÍŒŸo‚³‚ê‚Ü‚¹‚ñ‚Å‚µ‚½B
> AVG ‚É‚æ‚Á‚ă`ƒFƒbƒN‚³‚ê‚Ü‚µ‚½ - www.avg.com
> ƒo[ƒWƒ‡ƒ“F 2014.0.4158 / ƒEƒCƒ‹ƒXƒf[ƒ^ƒx[ƒXF3614/6776 - ƒŠƒŠ[ƒX“úF2013/10/23
More information about the FOSS-GPS mailing list
