[FOSS-GPS] Basic Question: Just Require 2 log files from RTKLIB
David14 dav.mercenary at gmail.com
Fri Apr 25 02:52:36 PDT 2014
Hello People,
Recently I found out receiver I was working with does not work with RTKLIB
unfortunately.
And my new receiver will arrive in some time so I wanted to request people
if they have some log files from rtklib that you can share with me and I can
write my code on.
I just need 2 log files from rtklib. One in which a receiver is static and
the other in which a receiver is moving.
The main focus of my project is to increase precision with dgps. So I will
place a receiver (receiver1) which is static and the other receiver
(receiver2) will be mounted on a robot. Both the receivers will be connected
separately to rtklib and I will be able to get data. receiver2 just acts as
a control.
Now I need 2 log files from rtklib for this.
I would greatly appreciate help on this because I have no other way to go
about it. Thanks.
Regards
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Basic-Question-Just-Require-2-log-files-from-RTKLIB-tp7572853.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
