[FOSS-GPS] RTKLIB errors and warnings
mazahirp
mazahir.poonawalla at gmail.com
Tue Feb 4 21:46:02 PST 2014
Hi All,
I am new to RTK GPS and RTKLIB. I am trying to understand and still work
around with it. Please help me with the following errors:
To start understanding, I place 2 gps receives U-BLOX 6T at a distance of 1
meter (1 as rover and 1 as base). Now I use RTKNAVI to input serial UBX data
and I select kinematic as the option. However, it displays position in
single mode and in the error/warning section, I get the following error:
"initial base station position error" What is this and how to solve?
Then, the I apply values of lat/long and height which I receive in single
mode to Options->Positions->Base station. Now it starts working in kinematic
mode but the result is always "float" and the baseline is never coming to a
constant value. Also in the error/warning section, along with other
warnings, I get:
"Invalid integer ambiguity resolution" warning. What is this?
Can anyone please explain as to what these mean and how to solve it? Also,
do I need to put in base station values as I did? Was it the right method?
Thank you the help.
Cheers,
Max
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-errors-and-warnings-tp7572812.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
