[FOSS-GPS] Using sp3 files with rnx2rtkp from RTKLIB-- no effect onsolution
Tomoji TAKASU ttaka at yk.rim.or.jp
Thu Jan 23 15:32:59 PST 2014
Dear Timothy
> Does anyone have any idea why the sp3 files are not
> used by the program?
Set pos1-sateph in the configuration file specified
by -k option.
See the manual A.2, B.4 and 3.5.
regards,
Tomoji TAKASU
Sent: Friday, January 24, 2014 8:09 AM
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] Using sp3 files with rnx2rtkp from RTKLIB-- no effect
onsolution
> Hello,
> I am trying to calculate the precise positioning of a receiver using the
> observation (*.o), navigation (*.n), and precise positioning (*.sp3) files
> with the command-line program rnx2rtkp from RTKLIB.  However, it does not
> appear that the *.sp3 files have any effect toward the navigation
> solution.
> For example:
> duly at remote2:~/GEONET/test$ rnx2rtkp 02130700.11o 02130700.11n -p 0 -o
> 02130700.pos
> 02130700-fine.pos *.sp3
> duly at remote2:~/GEONET/test$ diff 02130700.pos 02130700-fine.pos
> 3a4,9
>> % inp file  : igr16264.sp3
>> % inp file  : igr16265.sp3
>> % inp file  : igu16264_00.sp3
>> % inp file  : igu16264_06.sp3
>> % inp file  : igu16265_00.sp3
>> % inp file  : igu16265_06.sp3
> As shown, the only difference between the two processing techniques is
> that
> the program merely recognizes the *.sp3 files-- it does not appear to use
> them in the navigation solution.
> Does anyone have any idea why the sp3 files are not used by the program?
> Thanks,
> Tim
> Timothy M. Duly
> Graduate Research Assistant
> Remote Sensing & Space Sciences Group
> Department of Electrical and Computer Engineering
> University of Illinois at Urbana-Champaign
> airglow.csl.illinois.edu
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
