[FOSS-GPS] RTKLIB Vehicle Accuracy
Anton Strydom
agstrydom at gmail.com
Tue Jul 1 12:11:11 PDT 2014
Hi Nick
I have done a lot of testing with U-Blox LEA 6T at speeds of up to 120 km /
h. Lat & Lon does not appear to be a problem but elevation is a problem. I
paid the equivalent of $60 for the 2 receivers and ceramic patch antennas.
They are accurate on base line up to 10km where after accuracy drastically
degrades.
I do all my testing in real time and do not post process.
If you want to I can speak to my supplier and see if they still have some
of the LEA 6T's in stock at the price I paid for them.
Attached are photographs of the units I am using
Regards
Anton
On Tue, Jul 1, 2014 at 8:50 PM, Danny Miller <dannym at austin.rr.com> wrote:
> It does work in moving. But signal problems do still make the position
> jump around, trees and buildings and an antenna's orientation changing can
> make an error happen. Antenna quality has a lot to do with that, too.
> RTKLib requires a GPS with RAW pseudorange outputs. The NV08C is a good,
> cheap one to do it:
> http://www.nvs-gnss.com/contacts.html
> Contact your local sales rep there- it was actually easy in my experience
> to order a couple from them, and oddly cheaper than Newark element 14, as
> well as quicker to ship.
> Danny
> On 7/1/2014 1:24 PM, Nick wrote:
> Hello,
> I am interested in getting an RTK GPS setup working for a moving
> vehicle, not fast, perhaps 10 mph. I would postprocess the data collected
> later, using data downloaded from a nearby station.
> My desire is to log elevation data every few seconds as the vehicle
> drives. I hope to achieve 10-20 cm accuracy for the position and the
> elevation.
> As I research RTKLIB, it seems like most information I come across is
> regarding a static location. Is my goal feasible to achieve this kind of
> accuracy as the vehicle moves?
> If so, can anyone recommend a good board to get me started? I'm hoping
> to be able to do this for under $200 (just one receiver since the base
> station is public) -- please give me a reality check if this is unlikely.
> Thanks,
> Nick
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140701/70a429a8/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140701/70a429a8/attachment-0002.jpe>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140701/70a429a8/attachment-0003.jpe>
More information about the FOSS-GPS
