[FOSS-GPS] Raw Data from NEO-6M
Scott Harrison
scott at sharrison.net
Thu Jun 12 05:25:58 PDT 2014
seabass,
Yes you can. In fact I did a little work on a similar problem a short while
ago but I am traveling now and haven't got back to it. In my case, I was
writing a desktop app to configure the uBlox module in linux via a serial
connection (or FTDI usb to serial). I don't use Windows much and was
getting tired of switching operating systems to run uBlox. I have attached
a small Arduino Project sample file I found on Saintsmart earlier. You
should be able to get the example running with a few tweaks.
Good luck.
On Thu, Jun 12, 2014 at 1:55 AM, seabass <seabasscropper at gmail.com> wrote:
> Scott,
> I have been playing around with a Ublox Neo 6m receiver, and i have been
> using the UbloxRaw codes to enable Raw and SFRB messages.
> I'm wondering if anyone has got these codes working outside of U-Centre, do
> you think it is possible to send these messages via Arduino?
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Raw-Data-from-NEO-6M-tp7572786p7572920.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140612/fe74fc33/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140612/fe74fc33/attachment.obj>
More information about the FOSS-GPS
