[FOSS-GPS] GPS outage?
Joseph Muhlhausen
josibarns at gmail.com
Sun Mar 16 15:36:37 PDT 2014
Thank you Julio and Glen.
I collected the data on a pc running windows 7 and then post processed them
on my Mac in a virtual machine running windows 7. I will check my rinex
conversion.
Best,
Joseph
> Message: 1
> Date: Sat, 15 Mar 2014 12:25:57 -0700 (PDT)
> From: julio menezes <yjmenezes at yahoo.com.br>
> To: Open Source GPS-related discussion and support
> <foss-gps at lists.osgeo.org>
> Subject: Re: [FOSS-GPS] GPS outage?
> Message-ID:
> <1394911557.86156.YahooMailNeo at web162502.mail.bf1.yahoo.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi Joseph
> your data seems to be ok, all the time.
> I saw the rinex ecef position and they are close, for the 3 sessions, less
> than 3 meter.
> You are running under a virtual machine.? Are you a GNU/Linux user ? I am.
> please check your rinex conversion to output navegation.
> with convbin CLI,? use the switches? -n -g -s besides -o
> i hope it helps
> regards,
> julio menezes
> Em S?bado, 15 de Mar?o de 2014 12:34, Joseph Muhlhausen <
> josibarns at gmail.com> escreveu:
> Hello everyone,
> This is my first post on FOSS GPS.
> Yesterday, using a NVS - NV08C and a Tallysman 3430 antenna I captured 3
> series of raw measurements with the objective of post - processing them
> with a nearby CORS station in RTKLIB.
> After having collected the raw measurements and looking at them, it
> appears that I lost the signal from 18:00 to 20:00 (attached are the RINEX
> files).
> I don't quite fully understand what happened. Has someone else had this
> issue before? Is this a GPS outage?
> Thank you for your help.
> https://www.dropbox.com/sh/i7v3roli35nemr3/IfLpZkF5zw
> Joseph
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20140315/8aadae1a/attachment-0001.html
> Message: 2
> Date: Sun, 16 Mar 2014 06:45:23 +1100
> From: Glenn Thorpe <glenn at thorpies.com>
> To: foss-gps at lists.osgeo.org
> Subject: [FOSS-GPS] GPS outage?
> Message-ID: <5324ADD3.6000001 at thorpies.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Hello Joseph
> I have had problems using the NVS08 where the satellites somehow get
> negative elevation values. This has occurred even after the latest
> RTKLIB patch has been applied. I cannot recreate it, do not know what
> caused it. RTKLIB had been running for a number of hours it showed it
> no longer had any position and the elevation values were negative.
> Glenn
> Glenn Thorpe
> 8 Dixon Drive, Holder, ACT, 2611, Australia
> ph +61 2 6288 5748
> FOSS-GPS mailing list
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140316/e40e3f7b/attachment.html>
More information about the FOSS-GPS
