[FOSS-GPS] RTKLIB: str2str output rate
bjorn.spockeli
bjorn.spockeli at gmail.com
Thu Oct 30 02:56:58 PDT 2014
Hi, im using str2str as a tcpserver in order to stream ubx serial data from a
uBlox Lea-6T to a BeagleBoneBlack running rtkrcv with another Lea-6T. On the
BBB rtkrcv is configured as moving-base mode, receiving serial data from the
local Lea-6t and data from the base through tcpclient.
Im wondering if Im getting the full 5Hz update rate from the base, because
when I cycle through status in rtkrcv it seems that its receiving serial
data 5 times faster than the tcpclient.(Based on # of input data base ) Are
5 measurements sent as one tcp packet and #number of input data base only
shows the number of tcp packets received ? If not is there any way to
increase the output rate of str2str ?
Best Regards,
Bjørn Spockeli
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-str2str-output-rate-tp7573056.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
