[FOSS-GPS] Different Rover/Base Antenna Lengths
Jared Bench jared.bench at gmail.com
Mon Sep 15 07:29:44 PDT 2014
Does anyone know of a way to compensate for different antenna lengths
between rover and base station?  I get very poor fix rates if the antenna
lengths are too different.  I've tried specifying this as a phase offset in
the pcv file, but it doesn't seem to have any effect on the output.
I am running in moving-base mode with U-blox 7 receivers.  I have varied
antenna length from 230mm to 5m.
Thanks,
Jared
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140915/52c697d2/attachment.html>
More information about the FOSS-GPS mailing list
