[FOSS-GPS] Mobile Robot Experimentation
Yanqing
fishloveocean at gmail.com
Wed Sep 17 15:38:07 PDT 2014
Did you try with simultaneous mode of ambiguity resolution and use a smaller min ratio to fix ambiguity, such as 2 or 1.5?
Kind regards,
Yanqing
> On 17 Sep 2014, at 23:05, "Sean Hyde" <sean.a.hyde at gmail.com> wrote:
> Hey Guys,
> I’ve been playing around with RTKLib for a couple months now and have run into some issues and I was wondering if anyone had any idea on how to improve performance.
> ---Setup---
> Base Station:
> NVS08C on custom PCB using the receiver to power the antenna
> Antenna is Taoglas Limited AA.161.301111 (http://www.taoglas.com/images/product_images/original_images/AA.161.301111.pdf)
> Antenna is on a 12” x 24” steel plate
> Connected via FTDI->USB to Rasperry Pi
> Raspberry Pi runs str2str to send the data to Windows laptop running rtknavi using wifi backhaul
> Rover:
> Antenna is on a 18” x 18” steel plate
> The Rover setup is on a small mobile robot with a top speed of about 3mph. It is in a city (Pittsburgh), but the sky is relatively unobstructed.
> I’m running rtknavi in Kinematic mode using only GPS, L1+L2, 15deg elevation mask. The position that I input for the base station is a 5 hour average (though it seems to have lost some precision when I pasted it?). I have tried both Continuous and Fix and Hold Integer Ambiguity Res. I’ll try to attach screen shots of rtknavi.
> Right now, it kind of works. I can get relatively jitter-free floats and occasionally fixes, but these fixes don’t last long and I’m not sure they are actually globally accurate (ie: if you restart the software, you may get a fix, but it may be several meters from your last fix). Sometimes a fix goes away and never seems to come back.
> I’m wondering if you guys have any suggestions to improve these results.
> Better antennas? (Which ones?)
> Trying to get better placement of the base station?
> Different settings in rtknavi?
> Continuous vs Fix and Hold?
> Thanks!
> -Sean
> <image001.png> <image002.png> <image003.png> <image004.png>
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140918/bafc3fe4/attachment.html>
More information about the FOSS-GPS
