[FOSS-GPS] Mobile Robot Experimentation
Sean Hyde
sean.a.hyde at gmail.com
Wed Sep 17 18:02:44 PDT 2014
Thanks for the responses! I apologize for breaking the thread, but I had
turned on Digests by accident and couldn't figure out how to reply to
individual messages.
"I'm not sure what receivers you are using, but if it's this one:
http://www.nvs-gnss.com/products/receivers/item/2-nv08c-csm.html it seems
to be L1 only, not L1+L2. The antenna you are using covers 1574-1610 MHz,
so while multi-system (GPS/Glonass) it is also L1 only. The GPS L2
frequency is quite a bit lower, at 1227.6 MHz.
http://en.wikipedia.org/wiki/GPS_signals#Frequencies_used_by_GPS
As far as I know, GPS L1+L2 receivers start around $750 used (eg. Trimble
4000ssi on ebay) and much more new.
Hi John. I had completely overlooked the fact that the NV08C couldn't
utilize L2 as I had read a lot of information about using it in RTK setups.
I'm rather new to GPS. My understanding is that without L2 I will not be
able to get rid of ionospheric delay, which will increase error. Could this
be why my system isn't performing as I hoped? Can I get away with using an
L1+L2 receiver on the Base Station and not on the Rover?
"Did you try with simultaneous mode of ambiguity resolution and use a
smaller min ratio to fix ambiguity, such as 2 or 1.5?
Kind regards,
Yanqing
Hello Yanging. I tried instantaneous mode and it seemed much worse. My
Float solutions oscillated by several meters (instead of a tens of
centimeters with a drift) and I couldn't get a Fix. I tried reducing the
ratio in the other modes. Although that got me a fix more easily, I was
concerned that it wasn't accurate, as it was not repeatable.
-Sean
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140917/06aa1a4c/attachment-0001.html>
More information about the FOSS-GPS
