[FOSS-GPS] Mobile Robot Experimentation
Sean Hyde
sean.a.hyde at gmail.com
Thu Sep 18 05:16:29 PDT 2014
Hi Antonio,
Im glad to hear you say this as the NV08C manufacturer makes a big deal of
using this module to do this using RTKLIB and I was getting worried.
The base station and the rover are much closer than 100m.
-Sean
[mailto:foss-gps-bounces at lists.osgeo.org] On Behalf Of António Pestana
Sent: Thursday, September 18, 2014 4:06 AM
To: Open Source GPS-related discussion and support
Subject: Re: [FOSS-GPS] Mobile Robot Experimentation
If rover and base are close enough (say, no more than a few hundred meters
apart) ionospheric refraction pseudoranges disturbances will be pretty much
the same both for base and rover. Therefore mono-frequency observations will
suffice.
Antonio
2014-09-18 8:50 GMT+01:00 Yanqing <fishloveocean at gmail.com
<mailto:fishloveocean at gmail.com> >:
Dual frequency receivers could solve this problem. You need both the rover
and the base station receivers to be dual frequency.
Kind regards,
Yanqing
On 18 Sep 2014, at 03:02, "Sean Hyde" <sean.a.hyde at gmail.com
<mailto:sean.a.hyde at gmail.com> > wrote:
Thanks for the responses! I apologize for breaking the thread, but I had
turned on Digests by accident and couldnt figure out how to reply to
individual messages.
I'm not sure what receivers you are using, but if it's this one:
http://www.nvs-gnss.com/products/receivers/item/2-nv08c-csm.html it seems
to be L1 only, not L1+L2. The antenna you are using covers 1574-1610 MHz,
so while multi-system (GPS/Glonass) it is also L1 only. The GPS L2
frequency is quite a bit lower, at 1227.6 MHz.
http://en.wikipedia.org/wiki/GPS_signals#Frequencies_used_by_GPS
As far as I know, GPS L1+L2 receivers start around $750 used (eg. Trimble
4000ssi on ebay) and much more new.
Hi John. I had completely overlooked the fact that the NV08C couldnt
utilize L2 as I had read a lot of information about using it in RTK setups.
Im rather new to GPS. My understanding is that without L2 I will not be
able to get rid of ionospheric delay, which will increase error. Could this
be why my system isnt performing as I hoped? Can I get away with using an
L1+L2 receiver on the Base Station and not on the Rover?
Did you try with simultaneous mode of ambiguity resolution and use a
smaller min ratio to fix ambiguity, such as 2 or 1.5?
Kind regards,
Yanqing
Hello Yanging. I tried instantaneous mode and it seemed much worse. My
Float solutions oscillated by several meters (instead of a tens of
centimeters with a drift) and I couldnt get a Fix. I tried reducing the
ratio in the other modes. Although that got me a fix more easily, I was
concerned that it wasnt accurate, as it was not repeatable.
-Sean
This message is sent to you from FOSS-GPS at lists.osgeo.org
<mailto:FOSS-GPS at lists.osgeo.org> mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140918/a1f22972/attachment.html>
More information about the FOSS-GPS
