[FOSS-GPS] Why Gamin 18X is too precise?
Brian Wilson
brian at wildsong.biz
Tue Apr 7 10:45:51 PDT 2015
GPS uses Doppler to measure velocity. See
http://gpsinformation.net/main/gpsspeed.htm
and especially the comment that Garmin really is probably accurate to .5
not .1 miles per hour (or roughly knots)
In the 18X spec sheet I see this
1.6.3.4 Accuracy
> • GPS Standard Positioning Service (SPS) Position:
> < 15 meters, 95% typical
> Velocity: 0.1 knot RMS steady state
> • WAAS
> Position:< 3 meters, 95% typical
Maybe you are reading the wrong section? I don't see any reference to .05 m
/ s
Also note that "RMS steady state" implles they are doing averaging.
Hope this helps
Brian
On Tue, Apr 7, 2015 at 1:31 AM, solver90 <salimzairmilk at hotmail.fr> wrote:
> I have a Gamin 18X to do some experiment with it in urban area
> when i saw the manual
> (http://static.garmincdn.com/pumac/GPS_18x_Tech_Specs.pdf), this GPS has
> an
> accuracy in position of 5m in RMS, and an accuracy in velocity of 0.05m/s.
> My question is: How can we have this accuracy in term of velocity?
> (additional sensor inside the receiver, other signal used,....).
> Thanks
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Why-Gamin-18X-is-too-precise-tp7573172.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Brian Wilson, GISP
@brian_32768
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150407/da998929/attachment.html>
More information about the FOSS-GPS
