[FOSS-GPS] rtklib kinematic Stop Go post-processing with rnx2rtkp
julio menezes yjmenezes at yahoo.com.br
Mon Apr 20 17:14:28 PDT 2015
Dear Dr. Felipe  Nievinski,
Em seg, 20/4/15, Felipe G. Nievinski <fgnievinski at gmail.com> escreveu:
 Assunto: [FOSS-GPS] rtklib kinematic Stop Go post-processing with rnx2rtkp
 Para: foss-gps at lists.osgeo.org
 Data: Segunda-feira, 20 de Abril de 2015, 1:58
 Let me resurrect
 this old thread.
 The processing could be done in kinematic mode
 (either forward-only or forward+backward combined).  That
 way, initialization tricks (antenna-swap, fixed-length bar)
 as well as ambiguity reinitialization (cycle slips) are less
 of an issue.
 Then stop-and-go could be implemented forming
 weighted averages of the kinematic position coordinates and
 precision (3-by-1 vectors and 3-by-3 matrices).
 It'd require a time table of occupation
 start and end times (and marker name), which could be
 obtained simply grepping the rover RINEX observation file to
 extract event flags.
 If I were to implement this, I'd be easier
 for me to do it Octave rather than built into RTKLIB's C
 code.
 -Felipe.
 PS: the non-integer epoch seconds can be handled
 by teqc, see, e.g.:<http://postal.unavco.org/pipermail/teqc/2012/001310.html>
Thank you for your explanation.
I agree, instead build inside rtklib C code, i am using GNU utils ( grep, awk,sed, octave,... ).
I plan to use 1PPS signal to sync trigger events. ( closed loop ) and will write my own occupation time table logger  (gps time sync and epoch count... ).
best regards,
julio menezes
More information about the FOSS-GPS mailing list
